Gen2 Brumby tray trim clips still available :)
- 60766244
Are those the white clips to screw the black retaining clip/rolls for attaching your tonneau?
If so... where'd you find those? I want like 20 of them.
And the other clips,
Are they to suit the black external trim for outside the ute? I need 10 of those also.
- Silverbullet
Please tell me they're not dealer-only and in limited number...
Silly little plastic clips that fade away over the years have left me at a standstill more than once when doing something, would be nice to know there's a replacement still being manufactured.
These are the clips to hold the chrome strips around the tray (and tailgate) area on.60766244 wrote:Are those the white clips to screw the black retaining clip/rolls for attaching your tonneau?
Tonneau cover clips and straps are available from Clark Rubber.
Those white plastic clips are almost FROG only supply and as Paul says they are for the chrome surround trim of the tub of the Brumby. The round one is specific for the first screw to the left and right of the gate, under the corner piece of chrome trim.
Look, they even come with a rubber gasket for snug fit. Average cost about two bucks each
- 60766244
Ah.RSR 555 wrote:These are the clips to hold the chrome strips around the tray (and tailgate) area on.
All my chrome is held on by screws, and nothing more...
I suppose this is why I didn't recognize them.
I mentioned the tonneau because I'm looking for ways to get the round clips mounted on the car that the straps connect too added too for the new tonneau, and to repair the current ones.
The round one's (or some like them) are what I'd use to affix the rest of them when I attach some push studs for the new tonneau cover.
SCA has a special on tonneau accessories also right now.
I got some of these ages ago from Frog as well. I thought they weren't out of them yet but thought it was the chrome strip that you couldn't get anymore unless it's secondhand...
Or your local canvas joint should have them if Clarke Rubber doesn't float your boat in the price department.60766244 wrote:Are those the white clips to screw the black retaining clip/rolls for attaching your tonneau?
I would say not. But contact FROG and he'll be able to tell you what you need and what's in stock60766244 wrote:Are they to suit the black external trim for outside the ute? I need 10 of those also.
- Silverbullet
My chrome is held down by stainless screws, which thread into plastic plugs which are "clicked" into square holes around the top of the tray. These little plastic jiggers cause me so much grief60766244 wrote:Ah.
Mine must've gone walkabout at some point in the last 22 years.steptoe wrote:60 may have typed too fast, I should have explained that short screws seen at the top in intervals hold the chrome trims down to these plastic babies
Cheers for the expertise, as always.
P.S. Sweet as signature image.
- Scoobie Doobie
- Silverbullet
I found this website has an absolute ton of clips and fasteners (hence the name )
http://www.clipsandfasteners.com/default.asp
Dunno about the tray clips in particular but in the Subaru section there are many clips and pins that people may find useful, bits of plastic that degrade and fade after 20 years on the road. I haven't bought from this site yet but I plan on doing so to replace some of the bits on my wagon.
- FROG
$1.98 each for the two at the back corner
and $1.36 each for the other twenty required
plenty in stock at the moment
- Scoobie Doobie
