Power Window Wiring
Matt
Power Window Wiring
Post by Matt » Sun Oct 22, 2006 6:42 pm
Do the power windows use reverse polarity or just + 12v applied to the other side of the motor input? ( the three wire input motors on MY)
i.e
Wind up
Input 1 +12
Input 2 Earth (0V)
Input 3 Nothing
Wind Down
Input 1 Nothing
Input 2 Earth (0V)
Input 3 +12
Matt
"Claudia"
Matt
Post by Matt » Wed Oct 25, 2006 7:43 pm
Bump anyone?
"Claudia"
Smokey
Post by Smokey » Sat May 18, 2013 10:17 pm
Just in case 7 years on you are still looking for the answer, for L series at least 12V is applied to one side on the upwind and swapped to the other terminal on the down. Ie 2 wire.
Post by Bantum » Sun May 19, 2013 1:43 pm
The switching does all the reversing, as there are only two wires to motor ... :)
See here : More Details...
Cheers, Bantum ...
Post by El_Freddo » Wed May 22, 2013 11:25 pm
Bantum wrote:The switching does all the reversing, as there are only two wires to motor ... :)
Yep. Third wire is for the lock out switch - cuts the earth wire I think from memory - it's been a while!
