BOV
- tim_81coupe
A BOV releives the pressure buildup between the turbo and throttle body that occurs when the throttle is snapped shut. It is definitely worth running one, they can increase the longevity of the compressor wheel (as there is no air rushing back against it) and they also reduce lag between shifts.
My personal preference is the plumb-back type, I am not a fan of the atmospheric 'pssht' noise. Either will work as good as the other, however on a MAF controlled vehicle the atmospheric type will confuse the ECU resulting in a momentarily rich mixture.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
- Suby Wan Kenobi
- tim_81coupe
No the wastegate is the diaphragm actuated valve to the side of the turbine shaft that vents boosted air out the exhaust during periods of low throttle and high turbine speed (ie highway driving). In a nutshell it is the valve that controls the boost pressure.daza wrote:Actually, a BOV is a type of wastegate that vents to atmosphere normally via a trumpet, the only difference between a BOV and the wastegate factory fitted to your car is the wank factor of everyone hearing the BOV...
Daza.
Not at all to be confused with the BOV, which vents boost spikes that occur with the throttle shutting, as I said above. BOV's can vent back into the intake or to atmosphere.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
- Outback bloke
Not to be confused with the wastegate in the turbo itself. It opens once a preset pressure is achieved to stop over boosting. It is on the exhaust/waste side of the turbo.
A BOV is on the compressor of the turbo and is a vacuum operated valve. It is fitted between the turbo and throttle body. Under boost it remains closed and keeps the intake pressurised. When the Throttle body snaps shut it creates a vacuum in the plenum which opens the valve therefore releasing the built up pressure between the turbo and TB. With no pressure there it leaves the turbo open to "free spin" with no restriction. This keeps the turbo spinning nicely wich allows for quickspool up once the TB is open again. The more constant speed of the blades is also what prolongs the life of the turbo.
Atmo venting bovs may seem like pure wank factor but they can and usually do work better than the factory items. Factory items are generally too small for big boost/HP engines. It works on the same theory as exhausts. A small factory exhaust works but is very small and restricted. A good sports exhaust flows well and is usually larger in diametre. Factory BOVs on most EJ20s have a diametre of about 20-25mm. A good after market bov is any where from 30-35mm up.
Wank factor is the trumpet.
- Outback bloke
- Suby Wan Kenobi
- Outback bloke
- Suby Wan Kenobi
As told to me by a tuner today when picking up my car, more for high boost set ups, not really effective for old school engines like my EA82T.
