Fair enoughRSR 555 wrote: Somewhere between Tims Thicket and Whitehills. Hopefully too far for you to come![]()
You're welcome to join us but you don't like traveling more that 10kms from homeTOONGA wrote:Fair enough
Yeah Dan.. held together perfectly. I really didn't put it under too much strain (compared to when I last broke it at Two Rocks) but the little yellow car, now named Honeycombee (yes with 2 ee) as she is as yellow as honeycomb and has about the same amount of holesRock Ape wrote:I take it your cv is still in one piece? I got to look at fishes yay but bub enjoyed it and I have valuable brownie points!
Excellent.. glad you got that idling issue sorted. You had a very worried look on your face when you told me.. I was hoping the run home would clear it.Subydoug wrote:No worries mate, cheers for lunch. Definitely keen for next weekend, though I wouldn’t say no to beaches that arnt as chopped up. Poor old wagon wasnt running too crash hot when I got home . Wouldnt idle so I Pulled out the idle jets and they were clear. I ended up just starting from scratch with my idle tuning settings and now it seems to be running fine. Probably a little bit of dust, or perhaps a glob of oil inside the carby blocking some passages, and when I pulled the jets out and gave the carby a spray out its cleared it. Anyhow, running good otherwise. Il have a go at fixing the reverse jumping out situation tomorrow as its friggn annoying. If its what I think it is, it shouldn't take more then half hour to modify the bracket. I just hope the internals of the box arnt damaged.
Oh and do you think you could draw me a mud map of how you mentioned to plumb in the catch can?
Doug
