Gannon wrote:... You will need a bigger pump than a PS pump to run the blades ...
Hmm, my thoughts were if you had an electric operated oil pump going to blade motor ie: independent from engine - you could run one for each blade, plan is for two - is this doable ?
Got any other solutions ?
Gannon wrote:... Also, how will you address the lower gearing needed to make the tractor practical ... ?
If I were to keep it in the Fuji family, sounds like having to find EA dual range low gear set, or similar - another option would be to find a tractor donor gearbox that could be mated to the Subi Engine ...
Gannon wrote:... Turbo diesel engine would be the engine of choice ...
Yep, Another solution might be the new XV electric Hybrid, as the electric motor should be able to handle low gears ...
Cheers, Bantum ...
