New motor before moving to Adelaide
- PhilsWagon
Hi all!
It's been a while so I thought i'd post an update...
I'm moving to Radelaide in the next few months and am really pushing to get my wagon on the road before I go.
I picked up a donor car a few weeks back and stripped it for some parts that I needed and also a few other goodies like a bullbar and uhf and am about to get my hands reconditioned motor to put in. I'm also going to replace the clutch while i'm at it and install a new radiator (maybe a thermo fan too) as well as a few other things it'll need for rego like exhaust and a few suspension bushes.
I then plan to pack it full of my crap, hook up the trailer and start the long drive over.
As i'm running short on time I want to get all the bits for the engine swap together before I start so there is no running around trying to get bits half way through.
So, a couple of questions...
1. I've found two listings for clutch' - 225mm or 200mm flywheel?
2. Thermo fan size? Worth the effort?
3. Exhaust size? 2"? 2.25"? To help it breath a bit better but must be able to pass rego.
4. Anything I should look out for when swapping the engine?
5. Anyone have any experience towing long distance in the L Series? It's not a big trailer, 6x4 Tradies top full of tools. Not sure of the weight but definitely not heavy.
My wagon is an 89 MPFI 5 speed dual range Touring Wagon.
Any help or advise would be greatly appreciated.
Phil
Phil
only one clutch for the L Series EA82 4WD 225mm
12" Davies Craig will fit, SCA won't. I think it is worth it, but not coming from a towing perspective. Manual switches a bonus and easy enough to do.
Let it breathe too much and you could lose torque. Bigger costs more. 2.25 is ample on my turbo EA82. 2" is ample on my 250 ci that does 30mph per 1000rpm. EA82 will do 3000rpm at 60 mph. 2" should be overkill for 1800 EA82. and 1/4" more clearance
Degrease it twice before pulling engine out. Hmm 4Lo could have some useful gears in it for towing...it is awesome in the EA82T in the wet
Run some injector cleaner.
Thermo fan could do with a 50mm piece of ally angle to mount to bottom of radiator using fan shroud bolt holes, top of DC12SL then reach to top frame, redill, bolt and yummy. Mine will get a second DC12SL for the turbo side one day.
Speed up install process by ordering a week in advance new rad hoses CH2603 and CH2604. Cut the old ones to speed up engine out like wreckers do.
Make sure reco is the twin port mpfi heads not single port carby! That'd be a doozy !!
- PhilsWagon
- Silverbullet
- PhilsWagon
