Air filter box. Aluminium or steel?
I have been using that little open chrome filter on my Weber 32/36 and it was good in the winter. Now in the summer, the carb is getting too hot when the car is not moving.
I will adapt the stock blue filter box to fit the carb with a hose taking air in near the headlight. I have cut the bottom out of one and will make a new bottom out of metal.
I need something that will insulate the heat from the engine well, but I am not sure if steel or aluminium will be better for keeping the filter box cool.
- T.Farm.Brumby
Aluminium every time, whatever you can get really, it pretty much all acts as a heat-sink.
+1 for the sheeting Steptoe.
If you can get away with it, rip some headunits apart, they all have a nice big chunk of aluminium on the ass end that you can hack the teeth off, which acts wonders, also easy to work with if you have a decent grinder wheel.
Also, the CPU fans from computers are made of a nice aluminium alloy if you can get your hands on some, plenty of "blades" on them that you can sandwich together. Air gaps between them act as extra insulation as well (think voids in asbestos insulation).
Tom.
EDIT: PS. if you're sandwiching the fan blades together, it's pretty structurally pitiful, mostly just for thick insulation.
Tom.
All The Rigs:
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'89 Brumby "Brumbylicious"
'03 Outback "Uma"
'05 Forester
'86 RX Turbo "Thor"
'89 Brumby "Emma"
'03 Outback "Uma"
'05 Forester
So I made this thing. It is a bit rough, but I didn't have much time or tools and it does the job. Maybe with the body lift I will be able to fit an adaptor to put a normal Subaru airbox on the weber.
I glued some insulation foam that is used for boat engines or something on the bottom. It is silver underneath and lets no heat through, keeping the bottom of the box very cool even when everything else it hot.
Later on I might put a hose on the intake leading near the headlight for extra coolness.
