EJ20T with Anologe Sports Dash?
Any thing and every thing ever asked about how to do an EJ conversion to an L series and MY. Includes Brumby and Coupe.
Green_eyed_liberty
Post by Green_eyed_liberty » Tue Apr 14, 2015 6:49 pm
is anyone running an EJ20T (or any EJ series) and wired it into the Leone Coupe Sports Dash?
any hints would be awsome
cheers Tony
Post by Bantum » Wed Apr 15, 2015 12:31 am
Not yet - but two things come to mind, speedo & fuel gauges - they should be relatively easy to hook, up as long as they are calibrated suitably with matching hardware ... ;)
Cheers, Bantum ...
Post by TOONGA » Wed Apr 15, 2015 9:25 pm
Do you have an FSM for the year/s that the analogue dash was produced that would be the easiest way to find out what wire goes where.
the 1983 FSM here has the digital dash pin out / schematic but it looks like the analogue dash pin out / schematic has been redacted :(
Post by El_Freddo » Thu Apr 16, 2015 8:09 pm
It shouldn't be any different to wiring in an L series dash.
After wiring is done you should have:
- permanent power
- back up power
- oil pressure/warning light
- fuel pump
- tacho reference
- ing on
- start reference
And I think that's it. These wires will need to have the relevant wires found and connected. That's where the trick is.
If you don't have a pin out diagram pulling the dash apart would be the most effective way to find and trace what you need. Write down what you find as you go for future reference.
It's not as difficult as you think - just a wiry mess as you do it!
Proton mouse
Post by Proton mouse » Fri Apr 17, 2015 1:25 am
I have melded my analogue dash/loom with the EJ22 loom in my ongoing Brumby conversion.
I had the 22's loom professionally pruned by AMauto electricians up the sunny coast, and then blended it with the dash loom myself. I stripped off all the cover tape of the dash loom to trace and or add wires as needed.
I also incorporated a Liberty engine bay fuse box into the mix, which now sits sexily between the battery and shock tower.
One thing I still have to do is mount the oil pressure sender unit on a post under the alternator (in place of the basic low pressure only sender)
Other than that, it is all but finished in the wiring department but have not yet tested its functional capabilities :-(
Until then, I am hoping that when I turn the radio down, it doesn't also dim the headlights, or if I beep the horn, the windscreen washer squirts!! lol
Do you have anything specific you want to know Tony?
What a lack of full time female supervision can do for your kitchen table....
Green_eyed_liberty
Post by Green_eyed_liberty » Sun Aug 02, 2015 2:21 pm
any update on your prgress Proton?
wagonist
Post by wagonist » Sun Aug 30, 2015 5:43 pm
FYI, I don't know if its the same with the MYs, but the L series gauge for the coolant temp is a different range to the EJ sender. And they're different sizes :/
There are 2 temp sensors, one for the ECU (multiple pins) & one for the dash (single pin).
I modded (drilled & retapped) the coolant passage where the sender goes to fit the L version. Or find somewhere else to fit your original sender.
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
tony90
Post by tony90 » Mon Sep 21, 2015 4:52 pm
If you get the dash make sure you get everything-
IE crashpad, instrument surround, vents, wiring etc.
Found that out the hard way, cluster by itself is no good!
wagonist
Post by wagonist » Tue Sep 22, 2015 1:22 am
???? He's trying to make sure that his existing cluster works with the new engine.
Why the need for the rest of the stuff?
Current rides:
Previous rides:
Post by El_Freddo » Sat Sep 26, 2015 11:40 pm
wagonist wrote:???? He's trying to make sure that his existing cluster works with the new engine.
Because we assume that the coupe's "sports" dash is going into a brumby.
You can't just put the 6 gauge analogue cluster into a regular brumby dashboard - it simply doesn't fit without the matching dashboard.
It'll be mint once it's done mate ;)
Return to “Fitting EJ motors to MY & L series models”
