Gearbox Leak
majordad1
Gearbox Leak
Post by majordad1 » Mon Jul 13, 2015 4:32 pm
Having fixed the Oil pump leak issue now turn my attention to a transmission fluid leak in the Brumby. Appears to be on close inspection coming from the seal on Shifter arm sticking out of the extension housing. Looking at the Workshop manual I have it gives no dialogue on what is involved in replacing the oil seal on the shifter arm. Has anyone had to tackle this job. Majordad
Oil Seal ...
Post by Bantum » Tue Jul 14, 2015 3:23 pm
Umm... I'm assuming your talking about this seal :
I think it requires pulling the box out & a strip down to get to it ... ?
I could be wrong, but El_Freddo knows more about them ... :D
Cheers, Bantum ...
majordad1
Gearbox leak
Post by majordad1 » Tue Jul 14, 2015 5:26 pm
That appears to be the one Bantum except mine has the end of a split pin sticking out of it. majordad
Post by El_Freddo » Tue Jul 14, 2015 11:02 pm
Remove the shifter mechanism, do the bolt and slot trick while it's off. Once you've got that off clean up any burrs on the selector shaft, remove the old seal and replace with a lubricated new seal.
I think I used a deep socket to tap it back in place if I remember correctly. Pretty easy over all.
Another note, it's a good idea to thoroughly clean the area you're working on. Makes things very easy.
Post by steptoe » Wed Jul 15, 2015 8:58 am
Used to do mine on an annual basis due to some impatient dude who welded the shifter to the rail to rid the slop :( The weld extended into bashing the seal every 2nd and 4th gear shift. I think I just dropped box by the crossmember to work in there
it is NOK ARO 677G
gen # 80671 6020
technical 16,26,7 mm
majordad1
Gearbox Oil Leak
Post by majordad1 » Wed Jul 15, 2015 5:11 pm
Thanks for the input fellas, thank christ the gearbox doesn't need to come out.
Majordad
Post by El_Freddo » Wed Jul 15, 2015 9:15 pm
You won't need to drop the gearbox crossmember ;)
majordad1
Oil Leak
Post by majordad1 » Mon Jul 27, 2015 7:42 pm
Oh the joy of walking into the garage and looking under the Brumby to find nothing, not even the slightest speck of oil. All leaks fixed you beauty. majordad
Post by El_Freddo » Tue Jul 28, 2015 9:16 pm
Good work mate!
It's a great feeling isn't it?
