I know this is a common theme for Brumby owners as 3 out of the four I have had suffer from it. At the front of the tray in dead centre (between the two drains) there will be or will be sooner or later be a rust spot that if left un checked will end up looking like this one.
Yup, this one festered away and I failed to notice it when buying the car, oh it was not a hole then, it was caked rust flakes but this is how it looks NOW after I went crazy with my nibbler trying to find the edges that were still okay.
So what to do? patch it or think laterally and fit something into that location that would not look too out of place?
So shoot me down in flames, it had occurred that a slimline drain fitting could be put in there under the pretext that it is there to drain the tray when it gets flooded with rain?
http://www.bunnings.com.au/boston-stain ... -_p4750026
As my MIG welding skills are quite poor I have not considered patching it with new metal as the clean up and efforts to blend it in led me to think of other ways to fill the hole and make it a feature
Anyway, if you have a Brumby, have a good hard look at your tray NOW, there is a metal plate under that location that is harbouring moisture and a home for RUST... get out the fish oil and attack it before it is to late (like mine)
Regards,
Peter.
