RX CV Cups for Full Time Box Problems
We are in the process of putting the Full Time Box in my L Series. I have already got turbo cups (25 spline). We were adapting my CVs but we have hit a snag. We have used the cups - and the inner parts (with the balls) of the RX cups but the spline towards the outers does not match to the existing standard driveshaft on the car. The inner part with the balls was a different size to my existing ones.
I was under the impression all that was needed to be done was to "change the cups". Is there more to it than this? Is it possible I have Vortex cups and they are different?
- stamp_licker
Yes that is what I thought too - however the existing standard L Series cage and balls (is that what it is called?) are too small to go into the "RX" cup snugly.
Basically the "RX" cup and balls is bigger than my standard L Series.
When we tried using the "RX" Cup and Balls, we have a spline issue -:
Gearbox Stub ==> Cup ==> Cage and Balls ==> Problem Spline <== Outer CV shaft.
Sorry if I am being vague people - I am not clued on the correct terminolgy of CVs
- Chris_Rogers
Cameron : I am guessing the 23/30 is the outer shaft? So the RX and the standard L share the same outer spline in that respect? Just want to make sure if I do purchase the two (L + R) RX shafts that it will go onto my L fine.
Chris : Thanks for the offer - I'll see how we go. You don't have a spare pair of RX shafts kicking around do you?
- stamp_licker
nope.rx auto is the standard L spline inner,but the cup and shaft are bigger.jono wrote:Are the L series RX auto ( OK GLAT ! ) and L Series RX manual inner joint (DOJ) cups the same in this respect ?
i'm hoping the other way is to use lib inner cups on standard L shafts,i guess i'll find out in the next few days.
Building a hardcore postie:D
- Chris_Rogers
not yet. I may still need mind. they are available for sizing though.Fang wrote:Cameron : I am guessing the 23/30 is the outer shaft? So the RX and the standard L share the same outer spline in that respect? Just want to make sure if I do purchase the two (L + R) RX shafts that it will go onto my L fine.
Fang from memory I thought that the RX and MPFI cups were different – how do I know this? Well when I did the conversion I did not change the box (due to the lower ratio) and I could not keep/use the RX shafts as they were different.
- Outback bloke
The RX and MPFI cups are different in outer diametre. That doesn't matter though as the spline size where it goes on to the stub is the same. As the_postie has already said you can use Liberty inner cups straight on to your existing cv joints.
Hint 1: If you have already got the RX inners then it might pay to have a look at some 2wd front shafts.
Hint 2: Get some Liberty inners and put them on your existing cvs.
Beside all that I can get complete reco shafts for $140 each. Liberty, L series, MY, turbo, non-turbo, what ever. They come with 12 months warranty.
Thanks Brett. You certainly would have been cheaper (and closer to where the car is) - but I have got these ones now. They were $169 each. I was quoted $270ea by one mob!
I just want to get this beast moving. Oh what a "live and learn" experience. Thursday night is the night I hope it lives.
Incidentally, can you tell me which model Liberty I should use CV cups from? Be good to know for next time.
Thanks again all.
Thanks again all.
- Outback bloke
Crap looks like i was wrong again... i am good at that sorry.Fang wrote:No offence.. but I hope you are wrong Jaffa![]()
From memory yes - i have been meaning to email you just be SO dam busy.Fang wrote:Did I give you a sticker for your console Jaffa with that stuff?
