cv boots breaking
cv boots breaking
hi, howz does everyone stop their driver side inner boot from tearing ,i've busted several in the last year,read something about porsche make leather boots ,but i haven't been able to source any.
your car is obviously lifted then??....i tore one last week..
the only thing i can say is to learn how to replace them!...as they are only like $10 each...but a bitch to replace!
If it only seams to be that side and that particular joint all the time... make sure the boot is not getting dangerously close to your steering arm... it's possible it is hitting it and wearing it away. Some CV boot companys actually list a different part number for the drivers side compared to the passenger side to avoid this.
Dave
Dave
- Suby Wan Kenobi
if the car is turbo'd the RHS inner boot may be breaking because of the heat coming off the downpipe... Since my ea82t conversion around 5months ago the RHS inner boot has ripped...
$10 bucks a boot sounds good where you getting them from? i paid around $20 each :P
wrx_nut
wrx_nut
85' Touring Wagon, EA82T, 3" Lift, 27's, RS intercooler
90' Brumby (B&S Project!) still cutting rust :P
Yeah i pay a little over $20 for mine too... would be interested in where they are sold cheeper.
Dave
Dave
the shop is called Malz..they have a shop in cannington and midland, soon opening in balcatta...here's the page with the boots on it...
i bought boots last week for about $10, $12 max, with grease and the clamps!...note the complete shafts as well!...
sorry about the quality..had to change it so the file wasnt too big!
- Captain Obvious
belieive it or not super cheap have drive pro ones for $10 got a outer for the lib the other day!!
- SUBYDAZZ
re: boots
Definitely agree with the turbo heating making these perish quicker.
Folks I have spoken to have said it's more about the quality of the rubber, genuine boots go for around $35, though I have found a $10 will often last longer. Either way I think it's a fact of life that these things will go sooner rather than later. Keeping them clean of grime and dirt may make a difference too as you can imagine the more crud that is on the boot wearing into the rubber as it turns the less long-lived it is likely to be.
I wouldn't have thought it makes any difference whether your Suby is lifted or not, but with spring lift I would assume they are more likely to wear quicker due to changed CV geometry.
I'd actually like to try putting two universal type boots on the one joint to make it more long-lived, anyone reckon there's merit in that idea?
SUBYDAZZ
- SUBYDAZZ
Not sure how the steering shaft (column) could be too close to the CV boot, all Brumbys would be the same? If you bend the shaft I don't think that would be a particularly good idea, and surely when you turn it the bent part would either get further away or even closer?camo85 wrote:My brumby isn't lift just stock i think the steering shaft is to close to the boot,may b worth while getting shaft bent.boot only last like 2500k's with some 4x4ing.thank for the advice fellas
Or am I missing something here?
SUBYDAZZ
