Well bought this last week. Been good, few little teathing problems, had issues after degreasing the engine, wouldnt start jus wet coil. Was also running rough, pod filter pipe loose.
Got windscreen guy out today, took old screen out, lotsa rust around frame, going to clean it up, rust convertor + bog + primer should see a windscreen in later in the week.
Still need to work out why there is not horn working in the car.
Aside from that should be good for a road worthy by end of the week.
Future plans include cutting out all the surface rust from around the rear guards, inside the boot and various other small areas. 2 extra bonnet vents. Then a respray in white again.
Will be trying to find some bling bling flares from something like a Sprinter to cover the wheels a bit better also.
Will post more pics etc as I go.
