broke gearbox mounts again!!!
mattl200
Post by mattl200 » Sun Nov 27, 2005 4:21 pm
this is the second time in 2 weeks and i dont know whats causing it has anybody had any trouble with this before
the cars a 92 brumby with stock running gear
BlackMale
Post by BlackMale » Mon Nov 28, 2005 10:13 am
More info... did you replace broken 1's with with new bits?
Have you had the car long? Is it straight?
mattl200
Post by mattl200 » Mon Nov 28, 2005 6:46 pm
no i replaced them with second hand ones
but the cars in good nick some parts of the suspention could use some work but ill have to see whats left after the bills get paid
SuBaRiNo
Post by SuBaRiNo » Mon Nov 28, 2005 6:53 pm
These mounts suck at the best of times. Next time u get replacements... fill in some of the gaps with sikaflex and let them set before u fit them... they last a hell of a lot longer if u do.
Dave
Suba
Post by Suba » Mon Nov 28, 2005 8:40 pm
What are the engine mounts like , it could be related to the fact that they may be stuffed , and I wouldnt bother with second hand ones , not worth the saving.
Mike.
SuBaRiNo
Post by SuBaRiNo » Mon Nov 28, 2005 9:56 pm
I have been told MY gear box mounts are near on impossibly to buy new in WA. Hence me using Sikaflex in second hand mounts.
Dave
bluesteel
Post by bluesteel » Mon Nov 28, 2005 10:27 pm
even brand spankin new ones have waaaaaay to much movement for my liking... id say buy 2 new ones and fill the gaps with some sorta urethane
and it just so happens i have 2 new ones i dont need because ive gone for the 5 speed on the monsterwagon
pm me if you want them
Guest
Post by Guest » Mon Nov 28, 2005 10:29 pm
It might be worth checking your engine pitch stabilizer.
When the bushes are worn your whole engine/gearbox assembly will rock harder than Led Zeppelin every time you hit the gas.
SuBaRiNo
Post by SuBaRiNo » Mon Nov 28, 2005 11:02 pm
bluesteel What mounts are u using?? I have the 5 sp and still needed to stick with the MY mounts... what did u do to fit L series mounts (if thats what u did).
Dave
bluesteel
Post by bluesteel » Tue Nov 29, 2005 8:09 am
used the whole l series crossmember... looked stronger
i just held the l series crossmember up and decided that all i needed to do was drill 2 holes either side for it and grind off all the bits that were going to get in the way
once you know where its going to go and abouit where to put the holes for it just turn the MY crossmember upside down and drill the holes through it.. gotta line up that way
then welded some more reinforcing onto the ends of it where i cut out too much for it to clear where it bolts onto the car
ill get pics when i get a chance, but my camera dosent like bad light and the weathers been a bit poor lately
mattl200
Post by mattl200 » Tue Nov 29, 2005 7:54 pm
the engine pitch rubbers are good engine mounts might be a bit soft but not broken
but theres a local company in town that can fabrocate them to any hardness i want so i might give this a try if $$$ permits
failing this do repco or anyone have any aftermarket mounts the guy in burson couldnt find the gearbox ones and subaru wants an arm and a leg for them
Guest
Post by Guest » Tue Nov 29, 2005 11:16 pm
On my old MY I ended up just getting genuine ones from Subaru - yes they were rather expensive. I've spoken to SunSpares about this since though and they can send you some in very good nick for a fraction of the cost.
bluesteel
Post by bluesteel » Wed Nov 30, 2005 12:56 pm
i think mine are kelpro, got them from repco
they are still only rubber... not the fancy urethane ones and i did a lot of searching to not find anyone to make some urethane ones
and i still have 2 Brand Spanking New Ones if you want them :wink:
Post by steptoe » Wed Nov 30, 2005 3:47 pm
yep, kelpro have a listing for EA81 gbox mounts
i think gen are $72 each !
mattl200
Post by mattl200 » Thu Dec 01, 2005 8:44 pm
my price was 55 for gen mounts but thats ok
think i fixed it but i dont know the clutch had 2 springs that had fallin out and after fixing that it dosent shake anymore
but dont knoy if thats what made it shake in the first place
subanator
Post by subanator » Thu Dec 01, 2005 11:45 pm
SuBaRiNo wrote:These mounts suck at the best of times. Next time u get replacements... fill in some of the gaps with sikaflex and let them set before u fit them... they last a hell of a lot longer if u do.
Dave
Work for me too, and still going strong. MY mounts to L box.
daza
Post by daza » Fri Dec 02, 2005 12:09 pm
"Subarino said... bluesteel What mounts are u using?? I have the 5 sp and still needed to stick with the MY mounts... what did u do to fit L series mounts (if thats what u did)."
I'm currently collecting bits to convert brumby to 5speed, the box i have doesn't have mounts on it so i tryed some MY one's, they don't fit? bolts are further apart on L box?
bluesteel
Post by bluesteel » Fri Dec 02, 2005 12:16 pm
okay...
i thought it would be easier and stronget to make the L crossmember fit at the time because i had the welder and grinder out
the MY ones would fit im sure with a bit of work too! :P
oh and L seies mounts on the 5 speed box fit straight up to the MY crossmember but you have to stretch the rubber round so i doubt theyd last long that way
BaronVonChickenPants
Post by BaronVonChickenPants » Fri Dec 02, 2005 12:32 pm
You have to eleongate the holes on the MY mounts to meet the bolt holes on the L box, there's a few people here who did it this way, I customised the L crossmember so I'm only going off what I've read.
Using the MY mounts and crossmember is a much easier and tider approach, if I was to do it again I'd do it that way.
Jordan.
Post by steptoe » Sat Dec 03, 2005 2:04 pm
I'll vouch for that ! Elongate the holes on MY mounts to suit their respective sides on 5 speed box. Caution...elongated inwards on one side, outwards on the other. Know your left and right mounting brackets first, keeping in mind left looks different if you are lying on your back looking up.
