Fitting huge wheels under EJ stuts
Post by AndrewT » Thu May 17, 2007 7:21 pm
vincentvega wrote:damn that looks dodgy. talk about poor mans coilovers
you guys should realise that your going to lose a heap of suspension travel with these. They are aimed at road cars
Yeah but apparently u can get them custom made to whatever length/travel you need. It might end up being really expensive but I suppose its the only way to get these features...
- Good travel
- Tough enough for offroading
- Fit behind the tyre/wheel to allow for very tall tyres
I'll start experimenting soon anyways, Crossbred kit should arrive soon!
vincentvega
Post by vincentvega » Thu May 17, 2007 7:47 pm
if you are talking custom struts then its a whole different ballgame.
im talking about the cheap, commonly available coilovers.
Post by AndrewT » Thu May 17, 2007 10:18 pm
I heard u can walk into a suspension place and order coilover struts for your wrx and ask for them to suit whatever specs you give. I guess those must be expensive tho.
SUBYDAZZ
Post by SUBYDAZZ » Fri Jun 08, 2007 12:40 am
BYB-01 wrote:...Or, get some old air bag struts and do it that way...
Ivor pair of Gen1 Lib front airbag struts if anyone interested... See 4 Sale section
SUBYDAZZ
Outback bloke
Post by Outback bloke » Fri Jun 08, 2007 5:20 am
Just curious, but why do you think they look dodgy, Dane? I can see that if the base is alloy then you are going to have to weld a collar on your existing strut prior to fitting. If they are steel then the base can be welded. (once the insert has been removed of course)
