The factory manual just says to get #1 on TDC then match the scale, presume this means get piston on tdc before look at scale on flywheel then zoom in on ? TDC ? the factory diagram shows pointer on 8 btdc.
the gregorys manual says to set it to the timing mark
in the turbo case , i guess that is 20 btdc
instructions not the clearest at times !
have actually fitted it on tdc but gut says i should pull it out and do it my way. not yet tried to start - no ready yet - no ecu fitted - needs a raincoat
what have you EA82 gurus and the like, done ?
