Brumby and Wagon fuel tanks??
SuBaRiNo
Post by SuBaRiNo » Thu Jul 12, 2007 9:34 pm
Are these the same?? Im aware they made 2 different size tanks for the wagons... i can only assume the brumbys were the same.
I ask because... My brother has a 89 brumby that appears to need a replacement fuel tank... i figure it will be a million times easier to find a wagon tank than a brumby one.
Dave
Matatak
Post by Matatak » Thu Jul 12, 2007 10:21 pm
sounds like ur bros brumby needs a fair bit of work..
somethign to keep u busy with lol
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Post by steptoe » Fri Jul 13, 2007 12:07 am
swear my red 84 Brumby has a 60 litre tank, uncle says my white 92 Brumby runs out at 50 litres !!
90brumby
Post by 90brumby » Fri Jul 13, 2007 12:24 am
mine runs out at bout 50 as well i put 38leters in when the gauge was half full at our last 4x4 trip n yer it leaks so yer i think its only a 50lter tank
but does ny1 no if there the same mines got a hole at the top (dam tex screws through the tray)
i am wantin to fix this aswell
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Post by steptoe » Sat Jul 14, 2007 10:09 am
tex screw through the tray ! that's like me mate fitting his ED Falcon towbar, needed a bracket rivetted to the base of the spare tyre well. Rivet needed a hole drilled first. Spare needed to be removed first - and that was not in the instructions !!
SuBaRiNo
Post by SuBaRiNo » Sat Jul 14, 2007 6:27 pm
So anyone know if wagon and brumbys have the same tank???
They sure look the same.
Dave
tassyraider
Post by tassyraider » Sat Jul 14, 2007 7:57 pm
hi iv fitted early 80s wagon tank in 86 brumby,modded it for conversion dont no what the fuss is about fitted fine.befor modded defumed it.cheerz mick
current ej18 awd targa brumby
95 impreza awd sportz wagon
90brumby
Post by 90brumby » Sat Jul 14, 2007 11:05 pm
i reckon they should fit
Post by El_Freddo » Mon Jul 16, 2007 3:35 pm
90brumby wrote:i reckon they should fit
Yeah, i don't see why not, they're pretty much the same chassis design, just different body setup... wouldn't be too hard to make it fit unless there's a major suspension component in the way...
BlackMale
Post by BlackMale » Mon Jul 16, 2007 4:57 pm
Dave I have a carb tank out at home you could have, I could not see why it would be different however its out of the car atm so we can have a closer look if you like.
SuBaRiNo
Post by SuBaRiNo » Mon Jul 16, 2007 8:39 pm
Is it out of an L or and MY Jaf? I assume it's from an L since u have no MY parts. It wont fit if it's out of an L.
Dave
Return to “Trouble Shooting”
