Duel Battery Setup
wild_horse
Duel Battery Setup
I've just got my hands on some 2nd hand IPF Spot Lights and was wondering how I can get them onto my Brumby.
Will I need a duel Battery Set up. If so What do I need and where's a good spot for the second battery other than in the tray?
- BaronVonChickenPants
You don't need dual battery just for running some spotlights, unless you plan to use them everytime you drive the car.
The best way the do it is via a negatively switch relay that is only powered when high beam is on, also have an overide switch on the dash.
Then run a fused line direct from the battery to the relay, then to the lights.
Fuses to suit:
2 x 100W = 15A fuse
2 x 150W = 25A fuse
2 x 200W = 35A fuse
In my opinion anything more than this is just crazy, even 2x200W is borderline.
There used to be a picture floating around for this, any one still have it?
If you're planning on doing a lot of night driving with them then you might consider a 2nd or upgraded alternator, no matter how many batteries you have if you're using more than the alternator can supply you'll flatten them eventually.
Jordan.
Fuses to suit:
2 x 100W = 15A fuse
2 x 150W = 25A fuse
2 x 200W = 35A fuse
Jordan.
wild_horse
Cheers guys, I'm thinking a bigger / newer alternator will be the go.
In my last post I forgot to mention that I already have spotties mounted on the bull bar. The new IPF will be going on the roll bar. I also have a CD player and amp installed.
If any one can give me an idea of what altinator to get (a bigger one or newer one) that would be great.
The XT6 had a 90A alternator (but i doubt you will find one of those, they were never sold in Aust)
Read this, it may help. But its american
http://www.ultimatesubaru.net/forum/sho ... hp?t=48583
