Clutch gone
subusurfer
Clutch gone
Post by subusurfer » Tue Sep 11, 2007 11:34 am
i think the old L series clutch may have had its day, when i put my foot down sometimes it just revs with not a lot of forward movement, only really when i'm moving along but seems to feel like the clutch is half in almost slipping?
[SIGPIC][/SIGPIC]1991 L series, 2" lift, 14" desert rats, perfect surf wagon in need of extra power
Post by Alex » Tue Sep 11, 2007 11:48 am
time for a new clutch by the sounds. It will only get worse alot quicker from now on. Try not to slip it. Look around for some quotes, or do it yourself!
Post by AndrewT » Tue Sep 11, 2007 12:55 pm
yep definitely sounds on the way out. Try adjusting the cable just incase tho.
subusurfer
Post by subusurfer » Tue Sep 11, 2007 1:02 pm
well i had it serviced approx 5 months ago and was told that it was slipping but now its got worse, what sort of figure are we looking at for fitting of a 2nd hand clutch?
daveosubi
Post by daveosubi » Tue Sep 11, 2007 1:58 pm
Be carefull not to drive it too much as you can cause damage the flywheel and require machining.
I wouldnt bother with a 2nd hand clutch, there sorta like break pads and bed into their surroundings, and the amount of work to replace it again isnt worth it.
My clutch cost me around 220 maybe 240 cant really remember, not sure about labor had a friend do it for us I gave him a hundred and slab of jimmies.
subusurfer
Post by subusurfer » Tue Sep 11, 2007 2:14 pm
any tips on where to get a new clutch from?
Matatak
Post by Matatak » Tue Sep 11, 2007 2:36 pm
id expect around 600 if i was you.
and if u get it done by some1 they shuld be able to order the clutch for ya
otherwise places liek Coventrys, Repcos AutoOne etc
i dunno wt kinda places u haev over there but those we have here and id expect wuld have a clutch for an Lseries
Wagon is no longer....:(
The Subaru Wacky Workshop
-All About the WA Boys :D
Jussy
Post by Jussy » Tue Sep 11, 2007 3:08 pm
I can get brand new clutches for $170 :)
the full kit :cool:
I dont know what SHIMANO is but i like it!
subusurfer
Post by subusurfer » Tue Sep 11, 2007 4:09 pm
$170 :confused: how do u manage that?
Post by AlpineRaven » Tue Sep 11, 2007 7:04 pm
Clutches can be found on ebay and they're OKAYish... the price & quaility is what you get!... I'd go for PBR clutches.. I don't know how much for L series.
Shop around for one. Oh for Liberty one is $350 PBR brand.
julian
Post by julian » Tue Sep 11, 2007 10:46 pm
Hi Mate,
There is a brake and clutch place out by the brickworks market. It is in a cluster of shops on the north side of Ashwin Parade (off South road) next door to a little take-away place or deli... Think it is called Kent Brake and Clutch.
They have been really helpful for my problems in the past and stock a pretty massive range of clutches on site so no waiting for orders. I got a clutch kit for a classic Renault off them including pressure plate, clutch plate and thrust bearing for $125!!!!
Hope this helps.
Julian
2004 Outback H6
2004 Forester XS
Organ donation saves lives
Post by D3V1L » Tue Sep 11, 2007 11:48 pm
jus knows a person who is in the clutch business over here....
Phizinza
Post by Phizinza » Wed Sep 12, 2007 11:08 am
Full clutch kit for an EA81 cost me $210 from the local auto store.
Clutches can be hard to get aligned and it makes it hard to put the engine back on the gearbox if it isn't perfect. But I suggest doing it yourself anyway as it is so much cheaper. If you don't have an engine crane you can hoist the engine up using the beam of a carport or garage.. It only weights in at about 95kg.
subusurfer
Post by subusurfer » Wed Sep 12, 2007 1:41 pm
in terms of going about the removal and rebuilding, what have people done lifted the engine or dropped the gearbox?
Phizinza
Post by Phizinza » Wed Sep 12, 2007 6:48 pm
I find lifting the engine is a lot easier.
mattl200
Post by mattl200 » Wed Sep 12, 2007 8:46 pm
Phizinza wrote:Full clutch kit for an EA81 cost me $210 from the local auto store.
thought youd have a spare input shaft from one of your gboxes to line it up phizinza i cut a legacy tt box one up to make myself one
dont worry the gbox had first gear blown off it by some ricer before i got to it
Bumpty
Post by Bumpty » Wed Sep 12, 2007 11:16 pm
subusurfer wrote:in terms of going about the removal and rebuilding, what have people done lifted the engine or dropped the gearbox?
Dropped it, haven't lifted an engine before. Only issues with dropping is make sure everything is clean (mud does and will always drop onto you) apart from that, don't get stuck under it and you should enjoy the wonders of gravity. 8)
..until you have to put it back in.
julian
Post by julian » Thu Sep 13, 2007 11:23 am
Yeh input shaft from a dead gearbox makes a good alignment tool for clutch installation. Also some clutch manufacturers treat the pressure plates with a glue-like protective coat. Can make the clutch feel like it is slipping and confuse you when you try to adjust it over the first week, so try to get it off with a non-oil based degreaser like a citrus degreaser.
There is a poll somewhere on whether to pull the motor or drop the gearbox so check that out for opinion, but I would drop the box using a trolley jack.
Julian
2004 Outback H6
2004 Forester XS
mattl200
Post by mattl200 » Thu Sep 13, 2007 2:31 pm
last clutch we changed was my ea81 lifted motor out and back in hour n half tops
Matatak
Post by Matatak » Thu Sep 13, 2007 3:22 pm
depends id say
do u have Turbo, Psteering, or Aircon??
they all add mroe clutter in the engine bay and need to be moved when removing a motor
if u have none of them then and also access to an Engine hoist then id say go the Engine route shuld be easier.
if not then just get some mates round to ehlp u manauver the box around thats pretty easy to.
and the EA82 is harder to just remove than an EA81 isnt it?
