From initial inspection it was obvious that the bearing on the input shaft was bigger, and the syncros on the low range were smaller. The roller bearing on the end of the input shaft is the same size, and the splines on the start of the next shaft measure the same size, but I need to get some bigger circlip pliers before I can swap that bit over to make sure.
From what I can see/measure, where the main bearing is pressed on the input shaft, it is the same size on both shafts so I'm thinking that I can swap the bearing onto the EA shaft, swap in the 1.5 reduction gear, and swap the rest of the selector/gear/syncro thing from the EA box and it should all fit.
I really really really hope!
I should point out in the photos below that the EA input shaft I was using was my spare from a D/R Turbo box, the number of teeth on the gear is the same as the Forester one. The 1.5 low input shaft gear is slightly smaller.
Forester input shaft/low selector
EA input shaft/low selector
Forester reduction gear
EA Reduction gear
Input shaft housing - Forester on left, EA on right
EA on top, Forester below
Forester on top, EA below
