The All Wheel Drive GLF-5, Version 2.0
- tim_81coupe
Hi all!
Just though I'd fill you in on some "improvements" that have been made to my little wallet munching coupe of late. As you no doubt already know, the car is very far from it's factory form mostly thanks to me. I'll just fill in on the basics to begin with, it's been fitted with an EJ20G turbo motor, running the AWD box and rear LSD. Disc brakes all round and that about caps off the basics.
Now for the recent improvements...
I pulled the wiring loom completely, as anyone who's seen the car can attest it was a horrible wiring job. The complete Legacy loom sat where the passenger's feet should have! I've trimmed this right back, and mostly concealed it. It will be completely concealed before I'm done.
I pulled the motor and changed the timing belt, fixed an exhaust leak and cleaned it up a bit before putting it back in. I was surprised to see the clutch was in extremely good condition.
The turbo has been upgraded to a Mitsubishi TDO5H.
The new injectors are on the way, keeping details hushed.
The new ECU is coming too, also keeping quiet on this one.
Several other (small) performance mods have been organised, nothing too big here.
My new fuel system is going to be something, trying to find a new surge tank at the moment. I'll be using a Malpassi rising rate regulator and a better fuel pump too.
An oil catch can will be installed.
New bonnet planned!
CO2 - finally!
There are various other improvements being made across the board, so it should hopefully be a different car to drive afterwards. Hopefully it will be on the road in around 4 weeks, when it is you'll be the first to know!
New bonnet planned!
CO2 - finally!
- tim_81coupe
- BaronVonChickenPants
- tim_81coupe
Well I've been thinking about putting together a pair of axles using Redline grease, although this will hardly help the situation.
The local CV place reckon short of going custom axles there's not a lot I can do. So I'll carry two spares everywhere and if it becomes an issue then I will get axles made.
Yeah, they look bad when they go. The shattered cups do look worse than the shattered cages.![Very Happy :D](./images/smilies/icon_biggrin.gif)
- tim_81coupe
