Superchargers??? What do you know??
SuBaRiNo
Post by SuBaRiNo » Tue Nov 06, 2007 7:50 pm
Yeah... it's looking like i can actually get a custom made new pulley for the charger but i need to investigate if it will actually be small enough to get the PSI im aiming for.
An Overdrive crank pully is looking like it would be a mission too cos of the Air con idler pulley... etc
Dave
Outback bloke
Post by Outback bloke » Tue Nov 06, 2007 9:04 pm
Best place to run a boost guage is right at the throttle body. I am not sure where you would take your car in WA but there is a lot of dyno tuners around these days that can flash your existing ecu. That done with some 440cc injectors and a turbo fuel pressure regulator and you would have an awesome combo. No need for water injection means less things that can go wrong.
