Hatch Supercharger progress
- INEEDABEER
What time is lunch:mrgreen:SuBaRiNo wrote:It's pretty complicated Cam... so ya can;t exactly do that.
Update: IT'S RUNNING!!!!
Just need to remount and stuff about with the accelerator cable and some mild wiring and it will be ready for a test drive. Im guessing i will get to drive it about lunch time tomorrow.
Big thanks to Devil Dave for coming over today... helped me to keep on trucking on with it when i was close to giving up for the weekend. I had some dramas with hoses calapsing under vacume this time... we got it sorted though.
Dave
]Hey I know Jack Schitte![/SIZE]
it gorwls......makes a nice noise....the collapsing hoses bit is basically solved..its just the finishing thouches now..first test drive will be tmorrow...lookin foreward to it
test drive went VERY VERY VERY well...99% of the issues resolved...only issue now is the boost...seems to be running slightly less then what we think it should be running
dave
dave
its runnign slightly less then what it should be running :P
Yeah turned out awesome, noticeable power increasment but mainly torque improvment... Had a few teathing issues but got them sorted.
As Dave said... boost pressure is a bit low... don't know if we have done something but it appears to only run at about 3.5 PSI max... was sorta hoping for about 6.
Dave
Dave
3.5 PSI and it was blowing hoses and collapsing them under vacuum.....WTF thats nothing.SuBaRiNo wrote:Yeah turned out awesome, noticeable power increasment but mainly torque improvment... Had a few teathing issues but got them sorted.
Dave
Wagon is no longer....
ur an idiot matt...vacume is still at around neg 30 when butterfly closed..hence collapsing hoses...blowing them off?? thats caus it was hooked up wrong in the beginning
cant expect me to remember that and put it together lolD3V1L wrote:ur an idiot matt...vacume is still at around neg 30 when butterfly closed..hence collapsing hoses...blowing them off?? thats caus it was hooked up wrong in the beginning
thught u werre turning it off at idle neway Subarino.
3.5 is way to low u definetely want more
3.5 is what the stock supercharger runs..u have to remember its a supercharger not a turbo...principles are completely diffrent
Matt... stop posting in here... i want u to think for atleast a day before u post anything more in here. If you thought about things more before u posted u would have a lot more usefull posts.
Dave
Dave
Just a few more pics with the throttle body relocated and some pines changed... i am still currently changing the pipes yet again and i have a bit of a lead on something i can do to get a smaller pulley on the Supercharger to raise the boost a little more. It's till running very very well and im more than happy with the results so far.
Dave
Dave
Im working on it... turned out i was all mechaniced out i spent all day on someone elses car yesterday. LOL
Dave
Dave
I must say.... VERY NICE !!!! Well done
I would like to ask tho, How did you run the belt for the s/c? is it off the same belt as the Alternator or seperate? If it's separate you may be able to increase the size of the crank pulley to speed up the s/c..
yeah, he's using the same belt to run the alternator/power steering and super charger... pk5-1650... bloody big belt. he's looking into finding a smaller pulley for the supercharger, rather than increasing the size of the crank pulley and over driving the alternator and power steering pump. That'll require another idler puller mounted below the S/C so the belt will still clear the pulley below the radiator hose.... its a tight fit but will be AWESOME when its completed
09 Forester XT Touring Wagon
Yeah as Vidler said... there is all sorts of other problems when making the crank pulley larger. And i would probably only get away with a 10mm diamter larger pulley at the most due to the air con idler pulley bracket being close to it. This would also be at very big cost as it would have to be custom made. I can't find anywhere that does a overdrive crank pulley for an EJ.
Only real way to go about it is making the SC pulley smaller... which would mean i lose the clutch. Anyone that has had much to do with these knows thats no big loss. Im also trying to experiment with theses pulleys on the cheep cos there doesn't seam to be an exact calculation to work out pulley sizes and boost.
I don't mind spending big bucks on a pulley but i do have a problem with spending big bucks on a pulley that will give me not enough or too much boost. Aiming for 6-7 PSI. Although if i happened to fall about 5 PSI i will leave it at that.
Dave
Dave
