how many broken down subes do u have in the shed?....
hey all just wondering how many of you subelovers out there have broken down subes in the shed? i was just counting mine last night after adding another 1 ....snapped timing belt on a 89' mpfi touring wagon..lol
but i have the beige hornet...unroadworthy..1
sir wills my wagon...broken reverse and wheel bearings...2
my lifted wagoon..lift points craked..3
and sir wills rx turbo ej20t powered sedan...stuck in neutral...4
oh and my ex wifes 89 tourer snapped timing belt ...5
all good i dont mind just me and some of the southern tassie boys have had a bad run lately thats all (bluesteel doing a captive nut in scrumby) u know how it is but anyway i have something to do for the next few weeks have a good 1 lads cheers Ben
5 for me...
`89 Touring wagon - busted captive nuts, part way through new lift kit and Liberty hub upgrade - 1
`86 RX Turbo sedan - missing engine, gearbox, radiator, rear diff, unregistered - 2
`90 Liberty GX sedan - some rearend accident damage, missing engine and wiring loom, unregistered - 3
WackyBug - missing engine (for now), unregistered - 4
`85 Touring Wagon - rear hal cut, destined to become a trailer, unregistered - 5
(Yes that is my total number of Subarus....none of them work haha)
EZ30 L series - Monsterwagon
- tassyraider
hii have a
85 targa in the air,via awd gearbox transplant,nill reg
82 brumby soon to b lifted ,ej 20 na?
82 brumby auto major rust conversion nearly sorted
datsun 12 ute under construction ,sill panels then build a15 motor 4 it
couple of dirt bikes
ME
ME
current ej18 awd targa brumby
95 impreza awd sportz wagon
- brumbyrunner
just to add to the insult me and bluesteel were in the maccas drive thru less then 1 hour ago and the brumby gace up the ghost and stopped so i jumped put and pushed her thru the drivethru and around into the carpark...we think either idle air control valve pipe was pinched or the afm maybe?? dunno but 30 min later she started weird...lol all tassies i love it fatz
Well I have 3 and a half One my wagon more or less in the process of making it to the graveyard a lib wagon which needs the roof lining to be finnished and then be sold a brumby daily driver that shouldn't be running (It needs tappets done and the electronic dizzy put back in long story) plus a baja bug and I won't even mention my two holdens!
Broken Subes
I have only 1. 1991 Lib wagon, had interior fire and rear paintwork burnt so is destined for ute conversion. Has lift and Forester struts fitted and the EJ20t and auto are about to go in. Was offered an L series with blown head gasket yesterday, the comment being "better it goes to a good home rather than the wreckers"
Gen 1 Legacy GT 3inch lift and 28's
lol ha ha minus 1 less ex wifes l series tourer me sir will and bluesteel took it back tpo her house last night so only 4 nope i put a tyre back opn mine and the floor is being welded in the next week or 2....did i mention me and a tree had a bit of a tangle lst night too...long story
All depends on what day it is really, however atm I have the following
1 L sedan (being converted to an RX.
1 RX being striped down
and occasionally a busted red wagon.
well last night i put the wheel back on my wagon and i have about 10 acres to drive around on so we have a set up a sorta little hill climb/motorkana... grass a few rocks and trees etc but i was trying to get passed a fallen tree and the angle of the hill plus the leaves and grass made me slip down onto a fallen tree so i got stuck on the passenger side..
Sir Will got out of the car we had a look and the best option was to get the scrumby (bluesteel) and use a snatch and pull the front around so i could get off the log (which i was well and truely stuck on now) in theory it worked but in practice the brumby was nearly too light but in the end a snapped rope later the brumby got me off enough so i full lock left hand down and just dumped the clutch and drove off this tree all good had a look at the damage and 1 kinda badly dented sill panel and door later....
but it gives me a challenge to get thru next time.. Ben
- lenardleone
