Knock Sensor info
Knock Sensor info
Hi guys,
What sort of signal is given by the knock sensor....? Is it a constant voltage? How does the signal change when it senses a ping?
Can I trick the ECU into thinking there is a knock sensor connected....(I know its not advised etc, just need the info)
Thanks in advance
Paul
Thanks in advance
Paul
I really don't think you need to 2nf cap, as the knock signal is AC, if you simply disconnect, the ECU's knock sensor won't hear anything
Is any fault code occuring with it disconnected? maybe the ECU can do a smart check, like check for any signal wilst engine is running.....if it does that, how to get around that? maybe a signal generator...but now its probably getting too complicated.....
- Outback bloke
