My GT2 wagon
- Chris_Rogers
- Chris_Rogers
- Chris_Rogers
hard to describe really. its a loud throttle based whine that goes away when the second turbo comes in. tried to record it but the sound doesn't really come through.D3V1L wrote:charcoal canister shouldnt effect anything or even hint about causing any noises.......might caus a tad of surging but this box of yours should eliminate that...and yes...turbo whine is different..lmao....any way u can describe it any better? or is it just simply that...obviously i cant really offer any advice at all unless i hear it so sorry i cant be of any more help...
dave
need a second car to (legacy GT) to compare to. boost box is getting swapped back the thing is too laggy now. think the one I have in there now is a later one as it is plumbed a bit differently.
still need to set the throttle up as well - code 24 pops up if I back off too quickly. think its due to the fact that 0.480v is meant to be the low limit and its dropping lower than that and flagging the code.
other than that its one very wild ride once it gets moving.
It might be one of the crossover valves not shut fully and letting just enough air through to make a whistle.
- Chris_Rogers
- Chris_Rogers
mine has a OE one in the front left guard. probelm I have is it runs out of vac after a long climb (IE the car is ALWAYS on boost and the 5 solenoids in the boost box are running.) and when I nail it I get code 66 (TT fault.) I'm after an actual pump I can kick on when I plant the foot so I have a constant vac supply. I have the switch in place on the accelerator pedal - may as well use it.
good idea though. TT is a VERY steep learning curve for me (the fault codes anyway - the rest makes sense.)
- Chris_Rogers
- vincentvega
$5k?! That's insane!
Glad to hear you've still got her... Yes it was Fang who said it but also said that he couldn't nail it 100% (not that I was going to mention you mate). So I thought I'd dig up the post and see what was going on. Plus its been so long since an update on this project!
Sorry to hear about the gearbox, Alex (Keffa) could suggest some quick gearbox change tips for you
Hope its all sorted after you get the gearbox set the way you want it. This wagon really is a piece of work!
MORE PICS PLEASE!!!
MORE PICS PLEASE!!!
- Chris_Rogers
- vincentvega
my full rebuild cost me 2650 including valve body mods for increased line pressure. That was the converter opened up and serviced and everything.
You aren't building a 9sec drag racer! you jsut need your auto freshened up.
pm me for details if you like.
- Chris_Rogers
I haven't read this thread for a while.
I wish I'd known about those thin fans, that "may" have worked on my car, but I've given up & am returning it to stock(ish) to sell off.
anyone want a WRX engine with factory loom to suit an L Series?:p
And a completely rust free shell:p;)
anyway, did you end up getting the water temp guage fixed to read correctly?
To do mine, I removed the water crossover pipe from the engine (requires removing the inlet manifold too), removed the EJ sensor, welded up the hole & built it up more (the L sensor is physically bigger), then redrilled & tapped the hole to suit.
Current rides:
JDM GTII Touring wagon
Previous rides:
96 Toyota Caldina wagon
:???:Previous rides:
- Chris_Rogers
- Chris_Rogers
