Air Compressor (Menzel?)
mattims
Post by mattims » Fri Jan 06, 2006 12:40 pm
I have had for some time now the air compressor that you remove a spark plug and screw it in and start the engine. I used it the other day and it was actually much quicker than a cheap 12v compressor to inflate a tire. Is there any reason no one else seems to use these compressors.
The only downside i can see is it can be a little tricky to fit it on a hot engine.
BlackMale
Post by BlackMale » Fri Jan 06, 2006 12:44 pm
That and its a pain in the bottom (maybe)
Would there be some issues with the other chemicals being pumped into the tyre - not just air, CO2 ect.
mattims
Post by mattims » Fri Jan 06, 2006 12:52 pm
i dont belive so as its actually a little diaphragm pump run from the compression in the cylinder not just directly using the compression in the cylinder.
mattims
and .. arent you meanting to be fitting a new steering rack.
BlackMale
Post by BlackMale » Fri Jan 06, 2006 12:57 pm
See other thread.
Wilbur
Post by Wilbur » Fri Jan 06, 2006 2:10 pm
Things I can see wrong with it, without even seeing it.
Not all vehicles have spark plugs.
I would hate to sit there cranking the crapper out of my little starter motor to pump up small tyres, let alone a real 4x4 tyre.
You can buy good 12 volt compressors now.
You can buy endless air kits
You can buy Air-Up kits.
mattims
Post by mattims » Fri Jan 06, 2006 3:44 pm
the engine will run on 3 cylinders np so you dont have to crank starter.
My car does have plugs
its alot cheaper than good compressor i think.
Wilbur
Post by Wilbur » Fri Jan 06, 2006 4:02 pm
I don't like the idea, but then I don't have one so I don't need to like it :lol:
Clintsc9
Post by Clintsc9 » Fri Jan 06, 2006 5:40 pm
I had one for a while and they were great with the EA81 where you could get at the spark plugs easily.
It used a diaphram and pumped fresh air into the tyre.
No problem to run the engine on three and it was way faster than a 12v compressor.
It fell out of favour though with the EA82 as the plugs were more difficult to get to and the engine always seemed hotter.
Would be nigh on impossible now with the plugs in the Outback. :(
They were a great idea in their time, but over the years receeding spark plug placements and the popularity of diesel have probably caused their demise.
Post by AndrewT » Fri Jan 06, 2006 9:27 pm
Somebody needs to invent a special spark plug that functions as a spark plug AND a compressor. So it's permanently installed (until it needs changing like a normal plug) and has a valve that can be easily opened or closed to turn the air on and off. It could have one of those quick fit attachments like you get on air compressors.
Quick quick, I better run to the patent office!
SuBaRiNo
Post by SuBaRiNo » Sun Jan 08, 2006 12:26 am
I think something like that would have to be a modification to the head not the spark plug. I don't think u can mess around with the actual location of the plug.
Dave
Ben
Post by Ben » Sun Jan 08, 2006 9:08 am
SuBaRiNo wrote:I think something like that would have to be a modification to the head not the spark plug. I don't think u can mess around with the actual location of the plug.
Dave
Speaking of that - Nissan and Toyota know that their cars are used offroad (except for soccer moms) so maybe they should look at incorporating a air-up sytem into their heads, would be a reason to choose one over the other when it came time to get a big fourby...
Please watch before posting!
Oversteer
Post by Oversteer » Sun Jan 08, 2006 10:15 am
If the plug fired you would have a flame front heading down into your compressor......it would need to be made of somthing very tough to survive combustion pressure let alone a very hot flame front ! ...what if it got charged with fuel and then ignited.... BANG !
I have used these pumps before, on older landcrusiers etc....pain in the arse on a hot engine, and I`m pretty sure its not real good for your engine to be running with a dead cylinder and fuel still getting in there to wash your rings etc....... wouldn`t do it to a newer car !
OS
MY05 GT-STI DCCD 6spd 13.88at98.7
88 FJ62 Cruiser-5.0ChevTPI TT,6psi,Hi6,044,Wolf3dV4,FMIC
Post by AndrewT » Mon Jan 09, 2006 3:00 am
I'm going to try for the old "endless air" trick. I've got 3 or 4 air-con compressors here, just gotta try to squeeze one in the engine bay somewhere.
BlackMale
Post by BlackMale » Mon Jan 09, 2006 3:13 pm
or in the new trailer
