Liberty Auto Transmision input shaft
austcold
Post by austcold » Sun Feb 17, 2008 9:36 am
The imput shaft on the gearbox which the torque converter fits onto has pulled out when the engine was removed.
Problem is I can't push it back in, I have tried with rag and vise grips but no success.
Any ideas???
Austcold
seagull
Post by seagull » Sun Feb 17, 2008 10:35 am
There is a spring type retaining clip that needs to be compressed Grant & lined up when refitting
austcold
Post by austcold » Sun Feb 17, 2008 11:18 am
Oh O,
I am asuming the gearbox needs to come out and apart for this?
Austcold
ohsuby
auto.....
Post by ohsuby » Sun Feb 17, 2008 12:12 pm
if the convertr has cum off the small shaft with th rubber oring on it this will push back in and give it a little twist to lock into the splines.....watch out you dont damage the o ring(it dosent get any drive wot so ever.....
if the converter came off with the 2inch tube then dont hit it it will brake the oil pump drive just push it back in with the converter on it and gently lift and turn while pushing it back in......the converter bolt lugs shold be around 10 mill off the auto housing when fully back....
but watch the seal behind the converter if its nice and hard it will be very easy to brake........:):)
stamp_licker
Post by stamp_licker » Sun Feb 17, 2008 12:16 pm
Try rotateing slowly there are lugs that need lining up.
Building a hardcore postie:D
austcold
Post by austcold » Sun Feb 17, 2008 12:40 pm
No problems with the oil pump shaft (tube thing that plugs into the converter) it is the centre spline (input shaft) that is pulled out approx 20mm.
Looking at the downloadable service manual it is true that there is a spring pin located through the shaft inside the box.
The drive shaft is hollow and I can see some thing that resembles a pin.
? Can this be rectified without a full Transmision teardown.
Austcold
stamp_licker
Post by stamp_licker » Sun Feb 17, 2008 1:01 pm
You can slowly rotate that shaft until it seats.Ther is a old post that covers a similar prob.
stamp_licker
Post by stamp_licker » Sun Feb 17, 2008 1:17 pm
Ok found the link on another forum ,though it was posted here to ,http://www.rslibertyclub.org/forums/sho ... nput+shaft
Should explain it
austcold
Post by austcold » Sun Feb 17, 2008 1:48 pm
OK Sounds like I need to drop the box so that I can rotate it. I am unable to refit the shaft as it is now.
Austcold
Suby Wan Kenobi
Post by Suby Wan Kenobi » Sun Feb 17, 2008 4:20 pm
Last time i did one of those i had the gearbox out so i stood it on endto refit the converter but as Wil says ican be done by fitting the little shaft in the converter and gently refitting it whilst slowly rotating.
The long road ahead
austcold
Post by austcold » Mon Feb 18, 2008 8:23 pm
I took the gearbox to the transmision shop which reconditioned it and they removed the shaft and refitted it. I did not know that the shaft could be pulled out completely and was concerned I would damage it.
However it is all sorted now.
Thanks for the advise.
Austcold
Return to “Trouble Shooting”
