info on SVX
- maxxair
info on SVX
hello all you knoledgeble people. tell me all you can abot these SVX autos. are they any good? does the manual button even stop the TCU changing gears? where can i get wiring info for this mess, and also after a Computer has been wet (ie underwater) will she ever go again. looks/smells like brand new, cant see any damage. cheers all.
- vincentvega
yes they are a good auto, plenty strong enough behind an EJ22
if that TCU has been wet you need to disassemble it completely, clean it with a circuit board cleaner like safewash (or methylated spirits is good too) and then dry it in an oven at around 40-50deg until its completely dry.
if it has been powered up while wet its probably stuffed, but you miught get lucky.
- stamp_licker
SVX auto manual link :http://www.hi.is/~vladisla/Detailed4EAT_vladrulli.pdf
Yep manual button will hold the gear unless its over revving.
Building a hardcore postie:D
I thought the auto in the SVX was the same as the auto found in Libertys of the same era.
Thats a good find postie
Offtopic i know, but where do i find info on this beast of a car?Cam wrote:Rigoli's H6 Twin Turbo drag WRX
- stamp_licker
