Adapter Plates
PHATnob
Adapter Plates
Post by PHATnob » Sun Jan 15, 2006 10:40 am
How thick is the adapter plate 4 da ej22 to da L series gear box?
I heard 12mm. How much does it cost?
coupe
Post by coupe » Sun Jan 15, 2006 11:36 am
Anywhere between 12 to 16 mm.
If your careful you can make one yourself its not that hard to do.
You can make templates from each of the matching surfaces then cut it out of a 12 mm thick plate of alloy using a jig saw.
Then you drill and tap the holes according to what you need.
You also have to realign the holes on the flywheel to match.
If you talk to Subarino or Suba they can tell you more.
Steve from Sunspares sells a good kit for this i thinks its about $450 including a mod flywheel.
Check out his link in the for sale sections.
Cheers Pete
Use The Fork Luke
PHATnob
Post by PHATnob » Sun Jan 15, 2006 6:35 pm
Thx buddy. Thought it was sometin like dat. Just so happens i have a jigsaw.. :lol:
PeeJay
Post by PeeJay » Sun Jan 15, 2006 7:23 pm
Make sure you get the correct blades for your jigsaw and some cutting compound to stop the blades from gumming up.
wildhorse
Post by wildhorse » Mon Jan 16, 2006 7:44 pm
steve from rising sun gets my vote. awesome support too.
New plates on the way.
waggaclint
Post by waggaclint » Thu Feb 23, 2006 10:18 pm
how do i contact this steve from rising sun im interested in buying an adapter. thanks
bluesteel
Post by bluesteel » Thu Feb 23, 2006 11:10 pm
