So are you saying that only 2 injectors are working, or only 2 connectors are working?
Its hard to test the output of the injector, as there is always 12v there, just the duty cycle changes. But you can test the coils on the injectors with a multimeter, they should be in the range of 1-4ohms i think
The 1" hole for a resonator boot. Its just a chamber to muffle the flutter sound you get when changing gears. Not a vital component, the car will run fine as long as it is plugged.
EA82T not running, starts but stops
All the connectors work, only two injectors are working.
Hopefully Ill have another couple working injectors this week and can see if its running nicely on all 4.
Ah, so thats what the hole is for.
Ill check the resistance on the injectors tomorrow, but im not to fussed as Im getting another two for nothing. cheers for that.
Where is the best place to measure boost from??
The intake manifold.Ronin wrote:Where is the best place to measure boost from??
I put a 'T' piece in the vac line that goes to the little white canister behind the drivers side strut tower.
Sweet, thanks.
I actually have a spare vacume line coming from the intake behind the throttle body, below the mix screw (But not on the actual trottle bodie like the screw). I think its supposed to be used with automatic transmission??? Its a small one, ~3mm inner diameter, about 20cm long if that. If it is ment for the auto box (which i dont have) could I use that line for the boost?
