Its Alive
Its Alive
the brumby is alive again it got a exhaust today n ive just been for a quick drive n far out its fast
its got a few teethin issues but i will get it there also needs thermo fans, i wanna put in oil and temp guages engine stay rod and a few other bits n pices
tthe only semi major issue i have is that it surges a bit under load some times but then ffor no reason its all good again n when its good it hammers so im not quite sure wat is causin this yet but i will find out
the exhaust mob reckon its fairly high but i dono i think i must b use to it now
but i have very limited net use atm but i will keep a close eye on the board anyway
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
ye it now has complete lib suspenion Front includin lower control arms and rear impressa drive shafts lib steering colum n rack lib crossmember RS turbo brakes n big lift blocks in the front and rear
thats wikkid mate!! so you be up to take her to this pines this sat? gonna crank a day run
Hunter S. Thompson
Hunter S. Thompson
Awesome Tristan, can't wait to see it! The surging might just be a teething problem that will sort itself out once you put a few kms on it. They are always a bit grumpy after waking up from a conversion
btw I still want that lift kit off you!
EZ30 L series - Monsterwagon
- vincentvega
tristans brumby is extremely custom:P
all special made brackets and all that crap..too hard to explain...need pictures and talking face to face to explain it:P
ill try convincing him to get some pics on the net of it
dave
dave
I was going to link those but they were before the Liberty engine crossmember was installed so I'm tipping it was changed around again.
