cpu power?
shuffbag
cpu power?
Post by shuffbag » Sun Jul 20, 2008 11:58 am
if the cpu and back up memory wire are both wired "on" constantly befor the ignition switch, would this drain enough power to kill the battery over night?
if so should i leave the back up memory wired befor the switch
and connect the main cpu power to the "on" position after the ignition switch?
also did anyone else have dash light problems after the ej swap, and if so are the any solutions eg "charge/brakefluid/brake light" lights in perticular.
Outback bloke
Post by Outback bloke » Sun Jul 20, 2008 1:32 pm
If all your power wires are constant 12v then yes it is enough to flatten the battery. Generally not overnight but a few days will see if flat for sure.
Post by AlpineRaven » Sun Jul 20, 2008 4:01 pm
Yeah it'll drain couple of days, someone wired up an radio by-passing the ing switch, he went away for a week and the battery was dead flat, reason that he did that was to prevent memory loss on the radio(!)
shuffbag
Post by shuffbag » Sun Jul 20, 2008 6:11 pm
yep thats what i was thinking. i still have the memory wire befor the ign but have wired the main power after i hope this helps.
i brought a new battery just in case
shuffbag
Post by shuffbag » Sun Jul 20, 2008 7:19 pm
i have noticed that i cant operate the other windows (power) from the drivers panel. like there isn't enough power? this is with the new battery in.
the only other lead that i presume doesn't go via a ign switch is some of the old L series loom.
the auto electric guy had added a a wire from the alt straight to the ej loom right near the three main plugs.... may snip it see if it still runs could be where the power is draining from
