Picked them up the other day and they will require slightly more power than the Sherpa motor I WAS going to use. That's ok though, Rick is donating an appropriate donk to the cause.
Or an open diff with big discs that are independanly operateddibs wrote:steerind and drives . did you win loto steve lmao or mabe two motors i got a couple of hydraulic drives here if you want t look at using them
I don't see the point of this as you would be relying on loosing traction on one side of the unit to turn a corner - using disc brakes each side much in the same manner is much more efficent for turning purposes as well as braking, this is how I've seen it work on small bulldozers and I'm sure its the same or very similar on larger units too...dibs wrote:thats a pissa that thing was looking for it to show steve
i still recon two flywheels eather side of diff and two clutches on each driveis the way to go . need that beer steve lol
dibs
Ya not a know it all , but you are showing your age.. Banana splits.. Loved that show. loldibs wrote:
i had one of those banana split six wheelers simailr idea
older stile dozers where similar to
im not a nowit all
dibs
Put me down for one of those.brumbee wrote:<object width="425" height="344">
<embed src="http://www.youtube.com/v/XyX83q756UQ&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></object>
not sure if this will work, but is this what you have in mind??
