Update on my Brumby
Post by TOONGA » Wed Oct 27, 2010 2:56 pm
Venom if you have kept your original manifold then you will have one from factory
in the diagram I posted from the FSM the PCV valve is right next to the throttle body
this image shows the red arrow shows the PCV valve in place,
and the green arrow shows where it was before I cut the manifold to bits :)
another shot of the PCV
the uncomplicated emissions system (black spaghetti) drivers side
the uncomplicated emissions system (black spaghetti) Passenger side
weber adaptor plate showing placement of aftermarket PCV hole
and while I was doing this I checked the cylinder compression
cold all cylinders above 120 and no higher that 150
hot all cylinders 150 exactly
do the happy dance Image
Post by steptoe » Wed Oct 27, 2010 9:50 pm
That looks low enough compression to add.... A TURBO!!
Post by TOONGA » Wed Oct 27, 2010 10:07 pm
steptoe wrote:That looks low enough compression to add.... A TURBO!!
hey I only just put this engine in and I want it to last longer than Frank did
a blow through turbo would be great until the bottom end went pop and I was left with no motor :0
Im hoping this motor lasts for quite a while and it should :)
Post by RSR 555 » Thu Oct 28, 2010 2:41 pm
Well driving into big mounds of sand/rock won't help it last longer than Frank :p
Post by TOONGA » Thu Oct 28, 2010 3:53 pm
RSR 555 wrote:Well driving into big mounds of sand/rock won't help it last longer than Frank :p
But it did make for a fantastic action shot didn't it :)
and I hear a rumour that Frank may be up for a ressurection
Post by RSR 555 » Thu Oct 28, 2010 11:24 pm
TOONGA wrote:But it did make for a fantastic action shot didn't it :)
Yes it was a great action shot and goddam that photographer is highly skilled with that equipment :D
Frank will oneday return to his former glory and hopefully push a 89L Touring Wagon around.. One that can handle that little mound :mrgreen:
Post by TOONGA » Fri Oct 29, 2010 11:09 am
RSR 555 wrote:Yes it was a great action shot and goddam that photographer is highly skilled with that equipment :D
I could really make a joke about the innuendo in that statement but this is a family board
RSR 555 wrote: Frank will oneday return to his former glory and hopefully push a 89L Touring Wagon around.. One that can handle that little mound :mrgreen:
well in this case flat out was the wrong option and Im pretty sure my cow catcher was the big problem
and good to see Frank will live again Im hoping to be there with a video camera when that happens.
Im thinking white lab coats, electrodes, lots of lightning and jars of offal and other animal parts in the back ground
Post by RSR 555 » Fri Oct 29, 2010 4:56 pm
TOONGA wrote:Im thinking white lab coats, electrodes, lots of lightning and jars of offal and other animal parts in the back ground
I think the only white coats will be the men coming for you :mrgreen:
Post by TOONGA » Fri Oct 29, 2010 6:04 pm
RSR 555 wrote:I think the only white coats will be the men coming for you :mrgreen:
you see I leave the "highly skilled with that equipment" quote alone (to a point..... ahahahahahhaaaahahahaha) and you just have to take a low blow at the white coats comment :rolleyes::rolleyes::rolleyes:
ah well .......
on another note I checked my timing today are you sure it was on 7 degrees ?
we will have to check my timing light against yours as mine said it was on 4 degrees :confused:
Post by RSR 555 » Fri Oct 29, 2010 7:11 pm
Did you get sand in your giny today?? bhahahaha
I remember when you tightened the dizzy up it went fron 7deg to 9deg but I don't trust that dizzy or the way it's fitted.
Post by TOONGA » Fri Oct 29, 2010 9:36 pm
sorry boss don't have a giny just a gaping whole :mrgreen::twisted::mrgreen::twisted:
the fact is I don't trust my timing light it did come from woolworths for free many a moon ago (dont ask and I wont lie)
I would say it is in actuality closer to the 9 degrees it was set at or was until I set it again today.
Post by RSR 555 » Fri Oct 29, 2010 9:52 pm
TOONGA wrote:sorry boss don't have a giny just a gaping whole :mrgreen::twisted::mrgreen::twisted:
I would say it is in actuality it is closer to the 9 degrees it was set at or was until I set it again today.
Post by TOONGA » Fri Oct 29, 2010 10:08 pm
RSR 555 wrote:??
?? so I had a senior moment
hang me
Im off to edit my last post :)
Post by RSR 555 » Sat Oct 30, 2010 9:24 am
No probs Old Man :p
Well maybe today we can play with your timing and try it on some big hills :mrgreen:
Post by TOONGA » Sun Oct 31, 2010 10:03 pm
Well we sure did play with the timing ( I will take a picture of the dead cap at some stage) and one new distributor cap later the timing is done.
as well my 32/36 was grafted to the manifold, thanks for that Paul
the engine waiting for the manifold
more modifications
32/36 in place
the same linkage setup but on the left side of the engine now
a glamour shot
a big thanks to all who helped today
T'subaru
Post by T'subaru » Sun Oct 31, 2010 10:29 pm
Looks good Toonga:mrgreen:
Post by guyph_01 » Sun Oct 31, 2010 10:32 pm
What a special beast:) one of a kind....,
I love how the alternator sits in the middle
Good job mate:)
Post by RSR 555 » Sun Oct 31, 2010 10:57 pm
TOONGA wrote:Well we sure did play with the timing ( I will take a picture of the dead cap at some stage) and one new distributor cap later the timing is done.
more modifications
No probs at all Jules.. always fun and interesting when you come up :) Glad to see you took photos of me drilling your manifold and not us driving the 22B to pick up the new dizzy cap :p
Will be good to see how it goes (fuel economy wise) over the next couple of weeks.. as the 32 main barrel should be a little more efficient that the 34
Can't wait to get the adaptor plate made for the Fiori dizzy :)
phantomD
Post by phantomD » Sun Oct 31, 2010 11:00 pm
That's awesome, it sort of helps to keep the look 'n' feel under the bonnet of that period, and eliminates one helluva wiring headache. Looking forward to more updates.
I'm impressed.
phantomD
Post by phantomD » Sun Oct 31, 2010 11:02 pm
Is that a Brumby radiator? If so what fan is that, does it fit the existing holes, how much did it cost and where did you get it from?
