I was starting to see a common theme emerge there!D3V1L wrote:lol alex, thats a new record with how quick those pics have come up hahaha
and im glad that u made that comment down the bottom
It's Steve's new toy. Members name on here is last celtic warrior.Matt wrote:The real Questions is WTF is a range rover doing in your yard!! :P JKS
Hey Rick.. better hang on to that trailer.. I'm sure you're going to need it a lot.. and Steve will owe you big timertcb65 wrote:I would say, the pictures speaks for it self....
Bhahahahahahahaha.. Love it Alex but you don't need to suck up with that last comment.Alex wrote:
yes dave towed wanky heaps as well though :P
Hey Alex ,what size rubber you got stuffed under those subie guards,looks like you got some 15 inch rims,i assume you have a 6 stud conversion hey? Require much in the way of mods to stop the rubbing factor?Alex wrote:how about this?
wanky towing daves rex?
or this? wanky towing daves cruiser?
Now you just need the diff and gearbox to work in harmony and your away!last celtic warrior wrote:She hasn't been started in 5 years, has fuel so stale it actually smells rotten, waiting on plug leads to arrive so jimmied some Subaru ones end to end with a bit of fencing wire jumpering one to the coil, wound her over and guess what...
One sweet motor indeed. Not running on all 8 reliably yet, as the leads and fuel are sh!te and the carbies have been dry for 5 years and need seals... But not a sound can be heard inside the motor. I can't remember ever seeing a motor so smooth and quiet. Carby overhaul tomorrow, plug leads next week and some fresh fuel and she should be almost like new.
Oh, and after running, the oil is still a deep honey colour and perfectly clear, and the coolant is still so clean you could drink it, if it wasn't full of glycol. Volt gauge says alternator is charging perfectly, oil pressure gauge reports full pressure, temp is perfect (thermostat opened on cue too), even the tacho works as it should.
So far I'm pretty damned happy...
The chrome rims had 29 inch tyres fitted to them, I'm pretty sure they're a 15 inch rim from a yota surf or something of the like. 3inch kit and EJ turbo from an RS halfcut. If you do a search on the forum you should be able to dig up the build thread87rxturbo wrote:Hey Alex ,what size rubber you got stuffed under those subie guards,looks like you got some 15 inch rims,i assume you have a 6 stud conversion hey? Require much in the way of mods to stop the rubbing factor?
Nissan Terrano/Pathfinder but kinda the same.. they have a very good offset and yeah, Alex's thread has lots of stuff about the any changes that car went through.El_Freddo wrote:The chrome rims had 29 inch tyres fitted to them, I'm pretty sure they're a 15 inch rim from a yota surf or something of the like. 3inch kit and EJ turbo from an RS halfcut. If you do a search on the forum you should be able to dig up the build thread
