EA82T cooling system
Hey guys, noticed my Vortex got up to half temp really quickly when I drove it this morning, so when I got home I went to check water level and the rad cap was stone cold so I twisted it a little and the water in there starting bubbling and surging in the coolant bottle. After a few seconds the bubbling water stopped an I pulled the cap off and topped up the rad, didn't need any. Could this be a dodgey thermostat?
Canny
Canny
- Proton mouse
- Proton mouse
No you should replace it. Engines need a thermostat to reach proper operating temperature.
They will run without one but there are several risks depending on engine type and current cooling system health.
If its an EFI engine it will run constantly rich as the coolant sensor will tell the ECU its not up to operating temp.
Heater may not work well at all due to cooler water/coolant temperature.
Can get excessive wear on engine parts due to not being warmed up enough (same reason you shouldn't cane a cold engine, unless its a renter or you've stolen it lol)
Long and the short is, they are there for a reason so replace it!
oh yes, mine comment above comes with a warning as above, try it without for diagnostic porpoises only while you wait for a thermostat to come in. TT2041-180 rings a bell for a part number, you may need to check it is the high flow one though ??
I have only run mine a few tanks of fuel a year but been getting 10 on 95 and 8.7 on 98. Wonder what improvements I can get when thermostat goes in ??
I know I should run a thermostat, just waiting until I get motivated to swap in a new pump and rad sitting in the boot last three years
