need advice, ej22
need advice, ej22
Post by Alex » Mon Feb 26, 2007 7:39 pm
hi all,
as afew of you are aware, im at the start of the ej road...
i have found a reasonable 1991 ej22, with 250,000km...i have offered the dude $500 for it, and the loom, ecu, etc. What should i look for? any common probs etc.
the car runs, and it idles very nicely. The only problem is the harmonic stabaliser or whatever(pulley) is wobbling quite eratically, i realise it could just need to be tightened, but could there be a deeper problem with this?
cheers
SuBaRiNo
Post by SuBaRiNo » Mon Feb 26, 2007 7:53 pm
hmmm... Aspro had a similar problem man... he could never fix it.
Dave
tim_81coupe
Post by tim_81coupe » Mon Feb 26, 2007 8:03 pm
Could mean the mains are flogged too. I wouldn't be too keen on it personally.
82 MY Wagon, EJ20G
87 RX, EJ20G
89 Brumby, EA81
12 BRZ, FA20
Suba
Post by Suba » Mon Feb 26, 2007 8:29 pm
just replace the pully , should solve the problem , it did with mine .
Mike.
daza
Post by daza » Mon Feb 26, 2007 9:42 pm
90subiewgn wrote:The only problem is the harmonic stabaliser or whatever(pulley) is wobbling quite eratically,
If it's been wobbling too long it may have floged the keyway out on the crank shaft so much it means replacing the crank shaft.
Daza.
runs back to the QLD forum...
:D
Post by Alex » Mon Feb 26, 2007 9:47 pm
lol, actually i dont know why i put it in the wa section!
Post by AndrewT » Tue Feb 27, 2007 1:49 am
cuz we are da bestest, or somefink.
Yeah I'd take the pulley off and closely inspect the keyway, its a reasonable common problem. Aspro fixed his fairly solidly with some metal putty stuff I think but that still isn't a 100% fix. Not sure how long it would have lasted, he swapped motors only a few months afterwards due to blown head gasket I beleive.
Could definitely be as simple as a loose bolt but it raises the question why the dude doesn't just tighten it especially with people comming over to see it running.
vincentvega
Post by vincentvega » Tue Feb 27, 2007 8:34 am
I dont know whats available on the west coast, but on the east you should be able to find a much lower km motor for that sort of money.
a well looked aft4er engine will still be strong at 250,000, but i reckon you should shoot for something with lower kms
keep an eye on the rslibertyclub forum
Post by Alex » Tue Feb 27, 2007 10:56 pm
yeh thanks guys, im still keeping my eyes wide open
waggaclint
Post by waggaclint » Wed Feb 28, 2007 12:09 am
yeah i agree dont just rush in on first one have a good look around the lower the km the better....and if can see it running even better....iven if its in a front cut you can still run it....
2011 Forester X
Post by Alex » Tue Mar 06, 2007 7:56 pm
what do you reckon of a 1997 ej22? any faults with these motors and what are the main visible things i can check for when checking out the motor?
seagull
Post by seagull » Tue Mar 06, 2007 9:39 pm
Nothing I checked over on Saturday for you
fit a new timing belt when its out of the car Alex & your away
seagull
SuBaRiNo
Post by SuBaRiNo » Wed Mar 07, 2007 5:31 pm
That motor has done too many kms and too pricey for a motor you can't hear and see running.
I would expect them sorta dollars for a motor u can test run.. maybe even drive... to take someones word for it that u don't know i would not pay more than $450.
In saying that... most people i know of that have bought an un-tested motor have regreted it... find something u can test start... u will thank me for it later.
Dave
seagull
Post by seagull » Wed Mar 07, 2007 9:48 pm
we are not talking about the motor Chris has Dave , that one is fuked !
Post by Alex » Wed Mar 07, 2007 9:55 pm
we are talking about the 1997 motor Neil...i cant hear it running can i?
SuBaRiNo
Post by SuBaRiNo » Wed Mar 07, 2007 10:26 pm
Im not refering to whatever your on about either Seagull.
Dave
seagull
Post by seagull » Wed Mar 07, 2007 11:58 pm
Ok Dave :)
Alex , I got there just be for the motor was pulled from the car .I would ask for a compression test & be there when its done gear box was attached
* if its not I have a bell housing that can be used * & your welcome to use it for the test .
I would like to state I dont own the motor but I do know the guy very well & he is 100% true to his word .I would state on the start of the deal should there be any problems on start up you would like a full refund , he would have no problems to that .
These are good people , some thing hard to find these days in this industry
Neil
Return to “Western Australia”
