3inch questions
3inch questions
when installing a 3 inch lift kit do u need to replace any parts like springs and struts ?, plus dose anything else neede to be changed cheers?
nah. if your just upgrading from 2inch you should be right.
EZ30 L series - Monsterwagon
Nah they all work fine - I don't think they even needed to be changed on Lapsed's wagon which has a 4" kit (somebody correct me on that if im wrong tho)
3 is fine with brakes and cables... maybe need to trim a little more off ya radiator hoses but unlikely.
Your exhaust will sit 1 inch lower too... a lot of people get there exhausts modifed so they are up nice and high when they are happy with the size of there lift.
Dave
Dave
yer my 4 inch lift caused my zorst to sit very low (as some peolpe saw)
also the top n bottom radiator hoses need adjustin the gear stick sat quite low n thats bout it
tristan
Ps bolt ur 3 and 2 inch together n make a 5 inch that would be cool but very very weak
tristan
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
rigby your car is fine...although we did have big issues with your 4x4 linkages...hmmm...but everything should be fine...bar the exhaust may need some attention
I will bet my last remaining nut that your reverse problem is just a sloppy linkage.
Dave
Dave
u want to use his wheel carrier??? his aint comming off in a hurry
Sorry about the delay buddy... flat out ATM will get to you.
