ej22 conversion questions
simmo
Post by simmo » Mon Jan 02, 2006 6:41 pm
i plan on putting an ej22 into my 86 brumby.. an i've got a couple of questions...... do i need to replace the radiator with a lib one? will i need custom cv's? where can i get my hands on an ej to ea adapter plate? and finally what mods need to be carried out to the fly wheel?
any help you guys could give would be great.
thanks, simmo
Post by AndrewT » Mon Jan 02, 2006 6:51 pm
- You can just get your existing radiator inlet/outlet pipes modified to suit the EJ22 but it is advisable to get a full custom radiator made up. Usually they use Toyota Tarago tanks and a Liberty core for this.
- If you are using an adaptor plate to hook up to your existing gearbox then you won't have to change anything to do with the CV's.
- EJ to EA adaptor plates turn up once in a while second hand (SubaMike just sold his) but they aren't too hard to make - have a chat to Subarino about this, he made one and has a few pics on his webpage.
- I beleive there are two ways to get your EA flywheel to fit onto the EJ motor. The first is to slot some of the holes, the second is to drill a whole set of new holes in between the old ones.
- You will also need a heavy duty EA clutch and pressure plate.
That info should be fairly acurate but I will stand corrected when some MY boys pipe up :D
a.
simmo
Post by simmo » Mon Jan 02, 2006 7:13 pm
thanks andrewT.
i'm planning on upgrading to a 5spd ea82 box.. will that affect the cv's? i was also wondering what the diff ratio is on the 86 brumby seeing as the sticker on the diff has long gone :(
PeeJay
Post by PeeJay » Mon Jan 02, 2006 7:26 pm
When I did my flywheel I just filed out the holes to fit the EJ. Only took about an hour or so.
Dif ratio should be 3.7.
Gearbox is in the exact same location as before, so cv's are not affected.
simmo
Post by simmo » Mon Jan 02, 2006 7:51 pm
does the tail shaft need to be shortened to fit the 5spd in place?
BaronVonChickenPants
Post by BaronVonChickenPants » Mon Jan 02, 2006 8:18 pm
It actually needs to be longer for the EA82 5spd, the easiest thing to do is use the EA82 tailshaft and mount the centre bearing.
I wrote this up after doing my 5 speed conversion, 18mths later it's due for an update, the main point to be changed is that it's easier to elongate the bolt holes in the MY gearbox mount rather than modify the EA82 crossmember.
Jordan.
stinky
Post by stinky » Mon Jan 02, 2006 9:03 pm
AndrewT wrote:- SubaMike just sold his
He has??? I hope not, I was first in line for it. :?:
SuBaRiNo
Post by SuBaRiNo » Tue Jan 03, 2006 3:52 pm
It's easier to slot the flywheel holes.... u will see... they are VERY close to an exact match. Only a few mm's off each hole. A dremil can be used for this... or simply drill each hole out a little bigger like i did. You will soon see that there is no way that enlarging the holes can make the flywheel off center due to a locating sleeve on the motor.
Making your own adaptor plate is very EASY... u will need a peice of 12mm think ally plate and a jig saw. U can use thicker plate but i wouldn't go any bigger than 16mm. 12mm is the exact size difference between the EJ and EA bell housings.
Pics at http://community.webshots.com/user/subarino
Dave
steve_rising_sun
Post by steve_rising_sun » Tue Jan 03, 2006 6:06 pm
A plug.....
We sell adaptor kits with a redrilled flywheel, which has the old holes plugged with machined pins. The flywheel is then faced.
The plate is lazer cut from 12mm steel, 12mm alloy is cutting it fine on strength. All plates are drilled with studs fitted and are test fitted.
$495 plus freight
Steve
MUDRAT
Post by MUDRAT » Tue Jan 03, 2006 7:40 pm
Here's a tip for adaptor plates:
Don't buy from VolksConversions. I had nothing but problems with my kit, and when I called him up to ask him very politely what to do he was a total prick and didn't wanna know me.
Get one from Steve, not only is it $200 cheaper but the after sales service will be second to none. Plug plug plug now you owe me mate.
Monster Subaru sold to a good home!! Still a Subaru owner. Will try stay in the Ausubaru loop. Sorry :cool:
bluesteel
Post by bluesteel » Tue Jan 03, 2006 7:46 pm
i bought one of steve and it boltes straight in... one of the easiest bits of the conversion.... now if i only bouight a pre stripped wiring harness :oops:
subanator
Post by subanator » Thu Jan 05, 2006 12:49 am
If you do make an adaptor plate, make it out of Plate not Rolled aluminium sheet. Plate is harder/stronger.
Most boat fabrication shops know of this difference and cheap to get an offcut.
SubaRute
Post by SubaRute » Thu Jan 05, 2006 8:25 am
why dont you just put all lib running gear in ur brumby ?
-ej engine
-ej radiator (custom bracket to fit)
-ej g/box
-wire harness
-custom t/shaft
-3'' lift kit
-lib inner cups to fit on brumby shafts
-custom gear stick for lib box (ither lib or l series fwd)
-mod g/box mounting points
might be a silly question but this will all fit in the brumby :roll:
BRUMBERTY
Post by BRUMBERTY » Thu Jan 05, 2006 9:28 am
More plugging for the Rising Sun Fellas..
there is LOTS to do in a conversion, leave this bit to the EXPERTS.
$495 is cheap when you consider the materials that go into it.
Very impressive quality control- minimal tolerances and perfect fitting.
Happy New Year to you Steve and Eddie!
1989 Subaru WonderBrumby II
simmo
Post by simmo » Thu Jan 05, 2006 6:54 pm
i wanna go for a full lib conversion but i don't hav the funds..... my budget is about 2000-3000 grand..
wildhorse
Post by wildhorse » Thu Jan 05, 2006 8:36 pm
2 to 3 grand will leave you with ricing only. Sorry, but when you add up 1000 for an ej 22. 1000 to rebuild it to guarantee you don't have to take it out a month later, 2000 for awd gearbox and rear diff and disc brakes, not to mention the hidden extras we all come across. They alone add to hundreds plus. My basic exhaust cost me 440. and that was at bargain prices.
Hope I haven't rained on anyone's parade.
New plates on the way.
BRUMBERTY
Post by BRUMBERTY » Fri Jan 06, 2006 12:23 pm
Dude have a serious think.
First, always is brakes, (big enough to keep any rego inspectors happy)
suspension,
bushes,
Rear CVs,
Wiring,
Computor,
AWD box,
mounts X 6
matching diff,
all the linkage hassles,
Custom Exhaust,
I have spent $6K and done all the work (except the adapter plate)
myself.
It all costs Mate.
Good luck though.
wildhorse
Post by wildhorse » Fri Jan 06, 2006 1:21 pm
Hey Tasbrat, Happy New Year. Got your dash yet?
Post by BaronVonChickenPants » Fri Jan 06, 2006 1:54 pm
If you score some real bargains and do absolutely everything yourself it could be done for around the 3k mark, my project so far is upto $2,500, the only things I have left to buy are a clutch kit and some EJ inner CV cups and a few small electrical things like relays etc.
That $2,500 includes buying the car for $1,000.
You're best bet is to lurk the RSLiberty forums for guys who have just finished a turbo conversion and have an EJ22 to get rid of.
Xaymaca and myself went halves in an EJ22, ecu, loom and AWD box that was $200 for the lot.
Just be patient and things will come up for the right price, but at the same time, as wild horse has said, a rebuild may be in order.
Jordan.
BRUMBERTY
Post by BRUMBERTY » Sat Jan 07, 2006 9:49 am
wildhorse wrote:Hey Tasbrat, Happy New Year. Got your dash yet?
Bluesteel is bringing it up the coast today.
And thats after an RS forum user drove it from Adelaide for me for a carton of Beer.
A complete stranger with an RS, would you trust them??
Bloody oath I would and did.
THANKS JARRED AND JOHNNIE.
Happy new year to you too Wild man.
