Switches $8 from SupaCheap
Bout 25 mins to install and wire up
Hahahahahahha!brumbyrunner wrote:fill some ugly holes in your dash!
I should have known that - I've got an MPFI, even though the ECU is still wired in and trying to operate and the MPFI is on a bench in pieces it still pushes out codes - no temp sensor or crank angle sensor.LongtimeAddict wrote:I just wired the black and green plugs to switches and bingo - check codes at the flick of a switch!
