Alex's ej20g conversion
100kw verses 154kw at the fly
:D
thats blaspheme in the religion of wacky workshop! you wash your mouth !!!D3V1L wrote:the subaru wacky workshop was alcohol free today:) its AMAZING what can be aceived when alcohol isnt present:P
dave
Hunter S. Thompson
Hunter S. Thompson
ok ok...i might have had a couple of brews...lol
skidz big time!
Hunter S. Thompson
Hunter S. Thompson
hit a big brickwall with the wiring. Will take afew extra days and $$$ than i expected. I knew it was all going to well! At least the engine bay came out hella sexy!
timing belts and rocker covers have all been done also.
mmm... yes... set back caused by devil dave...apologies offered :P..... ill sort it out for ya buddy.....dave obviously not as clever as he thought he was
dave
dave
all sourced and done..jsut gotta plug sensors in and we are away
dave
dave
more pics.
painted engine bay
got the new clutch back today. Got it beafed to 2800lb. VERY impressed with the clutch dudes work. Also got the actual clutch disc beafed to wrx spec, and all surfaces machined etc. Note the two diaphragms. It was he only way the clutch guy could get soo much pressure into the l-series pressure plate.
Also strengthened the clutch fork today and installed new thrust bearing.
chopped out the xmember to suit the turbo piping.
Put the WRX engine harness onto the motor(tedious long winded bitch of a job) looks like everything will connect sweet.
And attached the adapter plate onto the motor.
The motor will go in tomorrow, just gotta do the main wiring harness and splice in the RS knock and cam sensors into the wrx loom.
Pray to dear god we dont come across any other problems!
painted engine bay
So you swappped the harness but you still need to change the plugs on the knock sensor and TPS?
Dave
Dave
yes. The rs loom has the sensors on long leads, where as the wrx has a plug which goes directly onto the sensor. Some simple cutting and joining should solve it.
nad dave the knock sensor and tps are now solved.....we just need to modify the leads for the cam sensor and crank sensor and thast all....we could go and buy the 2 sensors with the correct plugs on them but for $160 i think making these 2 fit will be easier
dave
dave
