Air filter problems
liberty
Air filter problems
Post by liberty » Sat Oct 18, 2008 6:00 pm
Hey everyone umm question i got a performance filter (cone shape) ffrom a friend and i took off the standard airfilter of the my subaru Liberty gx and i disconnected that plug that grey lookin one and put the performance filter on its sounds sweet wen reving but wen u want to drive it takes a while and then after 5 minutes the car woulndnt start again. and it lid up the CHECK ENGINE in my dash. What do i do and how much will it cost
INEEDABEER
Post by INEEDABEER » Sat Oct 18, 2008 6:12 pm
Put the air cleaner back on,you've disconnected a sensor.
]Hey I know Jack Schitte!
[/SIZE]
Post by Gannon » Sat Oct 18, 2008 6:12 pm
Sounds like you have unplugged the AFM (air flow meter)
Put your standard air filter back on, and remove the resonators that are up in the left hand guard. This will give you the same performance, if not more than a pod filter. Cost is zero
liberty
Post by liberty » Sat Oct 18, 2008 6:16 pm
Suparoo wrote:Sounds like you have unplugged the AFM (air flow meter)
resonator where is that located. my car is a liberty gx
Bumpty
Post by Bumpty » Sat Oct 18, 2008 7:35 pm
Take off your front right wheel, then take off the inner plastic guard and this is where you will find the resonator thing, not sure on what to do for removing it, haven't gotten this far myself ;)
Post by AlpineRaven » Sun Oct 19, 2008 8:41 am
if you disconnected AFM - the engine will not start at all.
Make sure these hoses are connected under the tubing that goes behind the inlet manifold.
Post by Gannon » Sun Oct 19, 2008 9:04 am
AlpineRaven wrote:if you disconnected AFM - the engine will not start at all.
Yeah it will, if the plug is disconnected, the ecu will go into limp mode and calculate fuel input from throttle position.
shuffbag
Post by shuffbag » Thu Oct 23, 2008 10:17 am
i ran a pod once it killed my afm, was your filter pre-oiled?
oil+AFM=bad
bobbyjimmy
Post by bobbyjimmy » Fri Oct 24, 2008 8:03 am
shuffbag wrote: oil+AFM=bad
No, only over oiled = bad AFM.
Post by El_Freddo » Fri Oct 24, 2008 10:14 am
bobbyjimmy wrote:No, only over oiled = bad AFM.
Not true, you only need a little bit of oil, say from an oiled filter, to stop the AFM from worlking the way it should.
To clean your AFM use some carbie cleaner followed by some compressed air - try not to give it the full blast, go gentle.
shuffbag
Post by shuffbag » Sat Oct 25, 2008 10:47 am
mine wasn't over oiled it was a pre oiled k&n
Return to “Trouble Shooting”
