Update on my Brumby
Post by TOONGA » Sun Jul 11, 2010 3:12 pm
RSR 555 wrote:Wrong time of the year for cyclones ;) so stop wishing me to come home :D and after hearing about the weather down there.. I might stay just a little bit longer (sounds like a beer commercial)
Well really hope you can check out those other things but I'd start looking at fuel. Let me know how it goes.
Ok so it is never the wrong season for a revolving tropical storm and yes there was a comedy clip (I can't find it) about start you bastard.
you all ready to hear my weekend of fun (hope you have a cut lunch)
what a weekend I discovered that my computer no longer let me run spybot search and destroy and a few other little programs to do with malware and antivirus software as well when I tried to search for a cure I kept getting directed to a known malware program masquerading as a anti spyware program, so safe mode was employed and I deleted everything in the caches temp folders and the hidden temp files deep inside the vault (widows operating system) eventually i rebooted only to have
Perflib_Perfdata_2c0.dat and Perflib_Perfdata_660.dat left behind safe mode again and delete same story when windows was rebooted and spybot still not working
another search lead me to a program called combofix and with nothing to lose I ran it 10 minutes later I had my system back
3 files buried in the registry and 2 more in programs that had been hijacked
so today I decided to have one more crack at PJ in between rain showers and howling wind I checked and cleaned the distributor again :rolleyes:
and then moved onto the timing belt
left side
right side look carefully now
and timing at TDC or so I thought
I put everything back together and shone a torch down the neck of the carby it really was a WTF moment as I had checked this the other day when PJ didn't start and there was nothing I pulled the carby off to clean this up
and pulled the plugs and what I thought was carbon turned out to be like a layer of red (nearly black) plastic on the surface I had a motor drowned in petrol I cleaned the excess petrol out with rags and while it rained again took time to brass brush the plugs clean and check the gaps were at 1.1mm
when the rain stopped I turned over the engine with no carby or plugs to clear anything left in Frank, then put everything back together and started PJ. she ran after a few seconds then stalled I nearly had a fit as I had left the accelerator cable off.
so I put the cable back in place and tried again just as the heavens opened up again (this time with a vengeance) PJ spluttered and coughed then ran and I made sure I held the throttle at about half until the big cloud of black steam disappeared then let PJ idle, then did and set the timing to 11 degrees +or - 2
so in the end it was fuel,(but nothing like I thought) distributor dirt (and timing) and fouled plugs (and not the timing belt:rolleyes: thankfully)
Im happy PH is happy my computer is happy now if i could just stop the kids from fighting over everything in the house
tired
Post by RSR 555 » Sun Jul 11, 2010 8:05 pm
Glad to hear it was something simple but it does begger to ask, why and how did so much fuel get down there??? I'd make sure the electric fuel pump is not pushing too much pressure on the needle and seat. Also check that there is a negative pressure (vacuum) in the fuel tank.. you may need to make sure the vacuum lines to the carbon cannister and fuel tank are correct. As any pressure in the tank will cause petrol to flow even when the fuel pump is off.
Timing Belt is aligned corrected and you are definately on TDC firing stroke when the arrows are pointing up. (note for those putting on there own timing belts that these marks are not for Timing Belt fitment) so this is the perfect spot to check the dizzy is in the correct spot for firing on #1.
And as for computers.. STOP DOWNLOADING PORN !! :D:D:D
Post by TOONGA » Sun Jul 11, 2010 8:48 pm
twernt porn it was a dud program for ripping dvds Im getting to the point where I may have to start buying legal software to stop getting trojans installed in the unpack of a program
I seem to remember you were the one that told me which lines from the canister went where :)
Post by RSR 555 » Sun Jul 11, 2010 8:57 pm
TOONGA wrote:twernt porn it was a dud program for ripping dvds Im getting to the point where I may have to start buying legal software to stop getting trojans installed in the unpack of a program
Iz has a good bug free dvd to avi program if you like?
And yes I was the one who told you ablout the lines.. when you had a Holley carby on it and don't know if anything was changed after you fitted the Weber??? and the lines are marked on the canister where they go ;)
Post by TOONGA » Tue Jul 13, 2010 5:28 pm
well I took PJ for a nice drive into town today and she is running really well again. seems I really annoyed a Canyonaro driver by getting him at a set of lights with out even trying.
Im sure I need to re-jet the carby (looking into prices on ebay)as it has a steady stream of carbon at Idle but for now Im just happy she is running well again
hopefully someone will be back from Exmouth this weekend so we can attack and finish an exhaust thats not part Ej18 and brumby mixed with Ej20 headers
90brumby
Post by 90brumby » Tue Jul 13, 2010 7:05 pm
if i recall that exhaust worked really well for the time it was made in and the time it was made LOL
good to now u got it running again tho let me no when u come up ive got those vacum gauges here too
The New Owner Of hatchie
A 00 outback for doner car
2 door wrx being restored
Post by TOONGA » Wed Jul 14, 2010 4:32 pm
90brumby wrote:if i recall that exhaust worked really well for the time it was made in and the time it was made LOL
well a cheese cake bribe has been offered and as I understand it the exhaust will go on this weekend so Im going to be in town from Friday night and the holley should be with me in a box with some other bits and pieces
Post by TOONGA » Thu Jul 15, 2010 3:39 pm
cheesecake is cooked and ready to transport :)
the holley is staying home I got the parts from the US and played around with the it for about and hour, replaced an accelerator cam with a gentler one and put a plug in where the power valve should be. I put it on PJ and she revved like a demon but as soon as I tried to put load on the clutch PJ stalled. so I tried again and got out of the driveway and about 10 feet down the road when there was a nice size backfire and a bit of power then flooding on a massive scale.
I parked up and pulled the holley of to find about 5mm of fuel in the plenum so if anyone needs a freshly rebuilt 350 holley (aka model #2300 made 1971) with newly bushed butterflys I have one Im prepared to sell for what it owes me which is 160 dollars, otherwise Im going to wrap it up in plastic and wait until I have a project it will work on.
and it seems Im now coming up on Saturday morning or wait am I allowed to go on Friday night...... nooooooo!!!!!! don't hit me I will be good
wrxer
Post by wrxer » Thu Jul 15, 2010 11:07 pm
toongs, that roo bar is still here if you wanna drop in
Post by RSR 555 » Fri Jul 16, 2010 12:35 am
CHEESECAKE !! did I hear correctly that it's cooked and could be in Perth as early as Friday nght?? well god damn what the hell am I doing here.. I'm starting the car and will be in Perth by lunchtime tomoz
1111giles
Post by 1111giles » Fri Jul 16, 2010 8:13 am
RSR 555 wrote:CHEESECAKE !! did I hear correctly that it's cooked and could be in Perth as early as Friday nght?? well god damn what the hell am I doing here.. I'm starting the car and will be in Perth by lunchtime tomoz
You had better be quick cos Toog's avatar has already found the scrummy cheese cake - and is tucking into it ! :mrgreen:
Post by TOONGA » Fri Jul 16, 2010 9:23 am
1111giles wrote:You had better be quick cos Toog's avatar has already found the scrummy cheese cake - and is tucking into it ! :mrgreen:
Yep you must watch those grues they are into everything, anywhere at anytime
Im coming up early Saturday morning
I will have the cheesecake who will get the coffees?
Jack I need an address from you I will send you an sms later (and thanks)
now I must get ready for work
wrxer
Post by wrxer » Sat Jul 17, 2010 12:56 pm
toongas avatar seems to have missed his mouth
Post by TOONGA » Mon Jul 19, 2010 10:02 am
ZOMFG WTF FML
words can't really explain a simple start to a very long weekend last Thursday evening I was driving around looking at blocks of land with my son when my thermostat failed not a problem I thought as the temp rose up but the became respectable again
Friday afternoon I turned the thermo into a restricter Saturday morning I drove to RSR preformance to do the exhaust (a simple 2-3 hours of cutting and welding) a valve regrind kit later the engine had headgaskets again and was back in the car
Sunday morning I drove from Trigg to the workshop and decided that I was imperative that the rear diff be replaced as it was toasted (I knew this but was putting it off until the exhaust had been done) ZOMFG did the last owner weld the inner rear CVs to the diff and why doesn't that moustache bar fit... and are those... shafts longer... oops perhaps thats not an MY rear end..... ummm Paul do you have any MY rear shafts?
eventually with the diff dramas out of the way and the engine sorted out we got a spanking exhaust set up on PJ nice and quiet but very free flowing and responsive too boot
A big thanks to Paul again and to Tristian as well for making light of a bad situation (and helping as well)
no pictures this time sorry as it was work work ( bang my head on a rear Disc brake scream swear bleed) work and get things sorted
and thanks Jack for the roo bar it may go on or the steel bohemeth I have taking up space in the workshop may go on
Post by steptoe » Mon Jul 19, 2010 12:26 pm
So, good to see another Brumby sorted again. Sometimes think if not for being Brumbys they may get put off the road and crushed.
Was there an L Series rear moustache bar or something else non MY?
Post by TOONGA » Mon Jul 19, 2010 5:42 pm
yes .... yes it was an L series moustache bar which is 4-5 cm wider than the brumby bar
which explained why it didn't fit
and I forgot to thank Laurence for driving me around to get parts while Frank was being beheaded (a big thanks)
dibs
Post by dibs » Mon Jul 19, 2010 9:10 pm
hi guys good story even though you get of subject sometimes hahahaha i get like that to
i got a ? for ya .how much clerance from the stearing would the dizy have in an unlifted brumby. i like this setup like you said gets you away from electric probs . im old and dont understand computer stuff .so you have converted me
good work .
dibs
Post by TOONGA » Mon Jul 19, 2010 9:14 pm
it would probably have the same amount of clearance using an escort dizzy but if you use a fiori dizzy you would have way more clearance you would just need to make or source an adaptor
dibs
Post by dibs » Mon Jul 19, 2010 9:19 pm
ta m8 trying to buy the one thats on ebay from pomy land just waiting to hear back from someone over there that can post it on for me
dibs
what sort of mods were done to the escort one
Post by steptoe » Mon Jul 19, 2010 10:25 pm
Curious as to how the dizzy escort MKIII hooks up. Is it in detail in this massive colection of pages? The idea is um EJ22 has cam with drive at one end on RHS head? Is a hole machined into back of head or is there a plug that is easy removed? Then how does this escort dizzy then mesh up?
Psst, don't tell anyone I am asking I have no plans to go EJ - sounds too, nah I am committed to EA82T until I run low on parts or funds
Jonno
